Where do you buy your Drivr Side CV shaft\axle?
  • 23 Replies
  • 6197 Views
Offline RJkick
  • 634
Re: Where do you buy your Drivr Side CV shaft\axle?
« Reply #15 on: February 16, 2012, 10:43:05 AM »
used factory built CV is on the way
Offline RJkick
  • 634
« Reply #16 on: February 17, 2012, 10:39:46 AM »
Looks like the Napa's are too short as this happened after a few whoops - 5 minutes tops
Is this more likely to happen on uptravel or downtravel?  See earlier pictures
Offline RJkick
  • 634
« Reply #17 on: February 19, 2012, 06:28:58 PM »
Could a broken strut cause this failure?
Also, I am trying to locate the part number to the cv axle shaft and am coming up blank so far
Any help if you know - thanks
Interparts-HX gm 3 601m 0611 and gm 100m 0511
Offline duncan4x4
  • 30
shackle reversal
« Reply #18 on: February 20, 2012, 12:32:44 AM »
does anyone have any pics of an installed shakle reversal kit for a samurai from low range off road?
« Reply #19 on: February 20, 2012, 08:13:57 AM »
On down travel.  Dropping a tire in a ditch, or stuffing the other side up climbing out.  When the CV is extended and has traction.
« Reply #20 on: February 21, 2012, 05:28:30 AM »
I dont know if it is a length or quality thing when it comes to the aftermarket (rebuilt) CV's. I do know that if you have done anything on your lift that allows it to drop further than just installing the strut spacer that you will have the over extending issue. So you dont trash another, when you get your replacement, peel back the boot after installing it and cycle your suspension with a floor jack/jack stands and see how if the bearings are hitting the retaining ring. If so, you may want to consider making a spacer out of one of your busted cv's by cutting the cup off and grinding it down to fit. This will give you another 1/2" or so.
« Reply #21 on: February 21, 2012, 07:03:59 AM »
Or install some limiting straps.
Offline RJkick
  • 634
« Reply #22 on: February 21, 2012, 07:57:41 AM »
Funny but I was searching for your posts and sent you a PM
How long should the straps be?  4Wheel Parts has a set of 2 for $44 but there are multiple lengths and your length is tested so I want to go with it
Also, At what points did you mount them?  I want to make sure I don't cause myself more problems.  And again your mounts are tested
Thanks for all the help This Board has always been a wealth of information and help to me
Offline RJkick
  • 634
« Reply #23 on: February 21, 2012, 09:00:57 AM »
I actually took the spacer out to try to avoid too much droop.  Because it is being done for no charge at an auto repair shop I can suggest they look but they aren't inspiring any confidence by not even noticing the broken strut.  I will be putting it up on jack stands to cycle the suspension as you suggested.  Even though the passenger side droops justs as much I am going to try to install limiting straps as BentParts has to try to save my Struts and CVs
Thanks again for your help I really appreciate all the support
