tracker/sunrunner hubs and other parts on 2002 vitara?
  • 1861 Views
Offline diftoyota
  • 253
« on: January 30, 2012, 07:26:45 PM »
my girlfriend uncle has 4 tracker/sunrunner junked for parts (1989-1998) and i wonder if the fron locking hubs would fit my 2002 4dr 2.0L vitara. i want to do this so the front shaft wont turn wen the wheel are turning to save a few mpg and shaft wear.
also is the transmission,t-case,shafts,rear end out of the 1989-1998 model fit my vitara? cause they are easier to find than the 1999 and up model
Offline diftoyota
  • 253
Re: tracker/sunrunner hubs and other parts on 2002 vitara?
« Reply #1 on: January 30, 2012, 08:00:19 PM »
i have read a few forum and seems like i can remove one out of a older tracker sunrunner without any issues? do i need more than the hub off the older tracker? like a spacer,washer....
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: January 31, 2012, 06:56:15 AM »
You need hubs, bolts and cones and they bolt right up
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline diftoyota
  • 253
« Reply #3 on: February 02, 2012, 06:53:27 PM »
cones?? never heard of those lol kinda like washers or??
Offline biker
  • 730
« Reply #4 on: February 04, 2012, 05:29:44 PM »
Yes, they fit on the bolts and into the holes on the hub body. You'll see when you take them off the donor
99 Vitara 2wd
10 Gr Vitara
