coolant leak from back right under car
  • 1743 Views
« on: February 09, 2012, 03:59:39 PM »
I bought a 2000 grand vitara in August 2011 and 1 1/2 months later found out the upper oil pan had a leak so they had to take out my engine, etc.
Now over the last couple of months every two weeks the coolant resevoir is low and I need to fill it. This weekend I checked it and it was almost empty. Today I went out to my car to drive home and notice a puddle about 15 inches long under the tow piece on the back right and it had a greenish tinge. Is this possibly where my coolant is going and if so what could it possibly be that needs fixed now?
Thank you in advance
Offline talonxracer
  • 1284
Re: coolant leak from back right under car
« Reply #1 on: February 10, 2012, 06:02:50 AM »
You need to get under the car and track that leak down, I would suspect a heater hose clamp was overlooked and not tightened.
« Reply #2 on: February 10, 2012, 01:34:34 PM »
I don't know why it would be that far back, are you sure that its not fluid from the rear window washer?
