EGR sensor
  • 1304 Views
Offline rbeny
EGR sensor
« on: February 14, 2012, 07:36:18 AM »
1. G.V 1.6l 2004.
2. Tester (OBD2) is showing EGR (code 0400).
3. Additional symptom:Fast accelaration couses an strangulated effect(a very short delay), as an intermmidiate reaction.
3. What are the common problems that cause this code ? What should be done for fixing? (pls' list them fr. the easyest to the mor dificult)
4. Where's the sensor's location? the connector?
What are the right voltages ? in idle? medium/high motor speed?
Offline jzap
  • 515
  • How difficult can it be?
Re: EGR sensor
« Reply #1 on: February 16, 2012, 03:24:29 PM »
I don't know how much they have changed over the years, but my '96 1.6L 16V OBDII threw an EGR code a while back.  The EGR had a steel tube running from the valve to the engine.  The end at the engine and the port that it connected to was plugged with carbon.
I took the tube off , ran a wire through it, cleaned out the port with a wire brush and carb cleaner, and it cleared the fault.  Didn't need a new EGR valve.
Jim Z.
66 Apache camper
