What is this?? Leaking oil bad!
  • 10 Replies
  • 3342 Views
Offline g35-coop
  • 31
« on: February 20, 2012, 02:19:41 PM »
Im leaking oil from this and it looks like its coming from where a hose used to be connect??  It is right behind the carb and just under the distributor????  If Im missing a hose where does the other end go to?  Is it an oil pump or?????
« Last Edit: February 20, 2012, 02:36:47 PM by g35-coop »
 *Image Removed*
Offline 87Suzi
  • 156
  • Love this little thing!
Re: What is this?? Leaking oil bad!
« Reply #1 on: February 20, 2012, 03:28:16 PM »
That is your fuel pump.
Offline Capt
  • 738
  • 28
« Reply #2 on: February 20, 2012, 05:05:43 PM »
Yes 87suzi is right.
this tube is not connected to anything, it a vent & excess oil on the back side of the pump diaphram is draining here.
it could be time for a new fuel pump. also check to see if your PVC valve is working correctly, if bad, it could be forcing oil out here.
Note, if you replace pump, be aware that there is a small push rod that is in the side of the head to work the fuel pump
lever, don't let it fall out or your new pump won't work.
CAPT
« Reply #3 on: February 20, 2012, 06:05:53 PM »
That is the fuel pump.  If there is oil coming out of the open tube, you need to replace the fuel pump ASAP.  Oil coming out means the diaphragm is ruptured and oil can leak out and gas can get into the engine block.  After you change the fuel pump, change the engine oil and filter, because there is a good chance you have gas in the oil.
Offline g35-coop
  • 31
« Reply #4 on: February 20, 2012, 08:00:51 PM »
Thats what I thought but didnt want to jump straight in without being sure thanks a lot.  Ill follow up with how it goes.
 *Image Removed*
« Reply #5 on: February 24, 2012, 11:15:31 AM »
My sami is doing the exact same thing!  If you find a good deal on a new mechanical fuel pump, please shoot me a message and tell me where you got it!  My leak is very minor, otherwise i'd be ordering the part right now!  Good luck!
Offline Boxcar
  • 936
« Reply #6 on: February 24, 2012, 04:20:21 PM »
$51.99 At Auto Zone......Boxcar...
God Bless
Offline g35-coop
  • 31
« Reply #7 on: February 25, 2012, 08:28:57 AM »
Ya I went to start it the other day and it was just pumping oil out of it like nothing else.  Im going to try to get it fix this week.
 *Image Removed*
Offline 02CalTaco
  • 196
« Reply #8 on: February 26, 2012, 09:28:01 AM »
You can also get a factory Suzuki one through the dealership for about $4 more. Some Suzuki dealers I've found online sell them for even cheaper but shipping kinda kills the deal.
I had to change mine out not long ago, the hardest part for me was cleaning all the old gasket off, it was a pain.
« Last Edit: February 26, 2012, 09:30:39 AM by 02CalTaco »
Offline g35-coop
  • 31
« Reply #9 on: March 09, 2012, 03:20:18 PM »
Got it fixed and everything working.  No leaks.  thanks for the help
 *Image Removed*
Offline tamarack
  • 38
« Reply #10 on: March 09, 2012, 05:25:28 PM »
I also had to replace mine this week. Got it from Napa and paid $80  :-[...ouch!  To add to the pain, the new pump is actually a little noisy. Guess I'll have to see how if it quiets down.
