Economical Option to a winch
  • 17 Replies
  • 4571 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: April 30, 2004, 05:29:41 AM »
I wanted an opinon on what I could use for self recovery of my sidekick.  I would like a winch but don't really have the money right now.  Is there a cheaper option that really works?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Economical Option to a winch
« Reply #1 on: April 30, 2004, 05:38:36 AM »
A friend with a winch.
The message here, is never wheel alone (yeah, I never wheel alone, sure, you betcha)...
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Bfunk
  • 406
« Reply #2 on: April 30, 2004, 06:22:11 AM »
But if you have a winch, you can wheel alone.I don't like going it alone, but none of my wheeling buddies go elk hunting.
Brian
Offline DoctorD
  • 68
  • No such thing as too many toys!
« Reply #3 on: April 30, 2004, 06:56:01 AM »
In search of new toy
Offline explosivo
  • 3157
« Reply #4 on: April 30, 2004, 07:01:18 AM »
how about this:
http://www.izook.com/reviews/mppuller/mppuller.htm
D
heh, I was just about to suggest a come-along. Seems to be a fairly popular self extraction tool around here, with all the rednecks who don't spend any money on their rigs :)
omghi2.us[/url]
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #5 on: April 30, 2004, 07:04:40 AM »
I Help a friend with this type of manual winch!
59.99 canadian $$$
29.99 canadian $$$
2 tons
I pull it's 86 toyota pick up easily from a big mud hole and with just one hand!
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #6 on: April 30, 2004, 08:02:13 AM »
Hi-Lift has a setup that turns your jack into a sort of come-along. Not all that expesive as I recall. Anybody who sells the jack should have the recovery kit.
'91, RRO Bolt-On SPO, 32" BFG Muds, 2" BS U.S. Wheels, Breeeze CO, Neon Seats, 5.8:1 T-Case, TT Mighty Kong Bucket, 1.5" RUF, 1.5" Rears, DT Shocks, RRO Sliders ,Rear DetroitEZ, OBA,Celica PS
RCrocs Team 509
Offline 1bigtracker
  • 3409
« Reply #7 on: April 30, 2004, 08:03:36 AM »
their is a really old trick.  tie a rope onto the rear rim.  try to get it under the tire some how and drive in revese(sp).  the rope will wrap arond the tire and pull you out.  thats a super getto trick.  also a Hi lift jiack can be used a a come-a-long
stu
Offline 1bigtracker
  • 3409
« Reply #8 on: April 30, 2004, 08:04:12 AM »
oh your too quick for me. ;D
stu
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: April 30, 2004, 08:12:17 AM »
Before I got any 4-wheeling stuff, I always carried a block & tackle along (double duty for Elk hunting).
Of course, a tow strap can really come in handy, too.
Bob
« Reply #10 on: April 30, 2004, 09:29:39 AM »
I've seen the Warn 8000lb winch for only 450 bucks.
Thats what I got, The cheapest one. ;D
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #11 on: April 30, 2004, 01:24:54 PM »
Hi-Lift, it'll do more than a come-a-long. Around $50.00 at Northern Hydraulics.
Offline TomKat
  • 211
« Reply #12 on: April 30, 2004, 02:21:27 PM »
 Ã‚ the rope will wrap arond the tire and pull you out.
stu
Yes, and also the brake hose and cv joint. Likely you'll have nearly no brakes and a ruined cv joint, also. I saw that "trick" posted in 4 wheel parts wholesalers mag a while back, looked pretty scary to me.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
« Reply #13 on: April 30, 2004, 02:34:35 PM »
Well you missed the post I saw about the drive shaft
and wrapping a strap around it to pull you out  :o
I think these are last resort tactics, not to be used
as an everyday unstuck option, keep an open mind,
some of these might be of some use someday, but
not everyday.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #14 on: April 30, 2004, 04:19:39 PM »
To start out get a HighLift jack, short piece of chain, 2 shackles and a long strap. A come along may be helpful but with the other items you'll be able to get out of most things.
I didn't have the $$ for a winch either so for now I mounted a donated 6000lb little winch in the back. With it in the back it sure is helpful and it's out of the weather.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
