Left tail lights not working. 87 samurai
  • 3 Replies
  • 2688 Views
« on: February 25, 2012, 10:51:08 AM »
My left tail lights and side markers are not working.  The right ones work fine.  I checked the fuses, bought another tail light assembly.  Still no luck.  I finally used a jumper from the right side to the left side and the tail light and side lights worked.  After 3 days and rain, the fuses blew.  Any help will be appreciated.
Kent
Re: Left tail lights not working. 87 samurai
« Reply #1 on: February 25, 2012, 12:56:41 PM »
Worked to try to fix for a couple of hours today.  Took the rear bumper off.  Traced the wiring harness to the front.  No noticable frays in the wiring.  At my wits end. Help!!!
Kent
Offline fordem
« Reply #2 on: February 25, 2012, 02:55:07 PM »
This pretty much points to a problem within the wiring harmess
And so does this.
Open the harness up or take it to an auto electrician - if you've traced the harness to the front, removing it and "untaping" it should not be a that much of challenge
« Last Edit: February 26, 2012, 10:36:15 AM by fordem »
« Reply #3 on: February 25, 2012, 07:29:04 PM »
Thanks, I was hoping it would be less time consuming.
