HEY WILD!
  • 72 Replies
  • 16929 Views
0 Members and 14 Guests are viewing this topic.
Offline 1bigtracker
  • 3409
Re: HEY WILD!
« Reply #30 on: March 28, 2004, 11:58:15 AM »
more time than i had planed it too.  i started last year and still not done(only have to lift the rad. now, then its done)  of corse i have to go and keep up with school.  have to keep those good grades coming ;) ;) ;)
stu
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: HEY WILD!
« Reply #31 on: March 29, 2004, 12:47:24 AM »
I did the frame myself in a weekend.  The rest took me the rest of the week.
Raise the motor
               ratior
               lengthen the lower rear arms
               Drive shaft
               other stuff that I had to undo from the body lift
32 MTR's Warn 8000i
Offline Speedracer7c
  • 2210
Re: HEY WILD!
« Reply #32 on: March 29, 2004, 12:49:40 AM »
Interesting.
Offline Rod
Re: HEY WILD!
« Reply #33 on: March 29, 2004, 06:01:04 AM »
With the 3 inches of lift front and rear, did you have to lengthen your brake lines or drive shafts?
You said that you were able to fix the front toe-in with the strut extension.  Did you have the front end realigned or did you just eyeball it?
It's hard to tell by the pic exactly how you fabricated the rear extention.  Is it a round spacer?
Rod
Rod
Offline 1bigtracker
  • 3409
Re: HEY WILD!
« Reply #34 on: March 29, 2004, 06:55:46 AM »
Raise the motor
               ratior
               Drive shaft
i never  lenghened the lower arms.  it dosn't look too bad to me?  sould i?
stu
Re: HEY WILD!
« Reply #35 on: March 29, 2004, 07:04:56 AM »
Rod
I loosened the brake lines, drive shafts work but should be longer,
I had it alligned, but I just measure and set it now. 1/64th" toe in.
Rear spring spacer is a heavy pipe 3" Dia 5" long.
I'm going to work on a SYE setup and I'm thinking
of using Sammy Drive Shafts being they have flanges
on both ends and a slip shaft in the middle.
I'll post it when I get it done, With Pics for NY Kicker
he likes Pics  :D
« Last Edit: March 29, 2004, 07:05:26 AM by wildgoody »
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: HEY WILD!
« Reply #36 on: March 29, 2004, 09:31:50 AM »
stu
I never though of not doing it.  With a longer control arm you'll bet better articulation in the rear.
If you don't it will rotate you axil, probaly bind your shocks and of course limit you travel.
« Last Edit: March 29, 2004, 09:33:42 AM by lil_Truck »
32 MTR's Warn 8000i
Offline Rod
Re: HEY WILD!
« Reply #37 on: March 29, 2004, 11:23:55 AM »
You mentioned a 2" spacer in the front (I assume that it is similar to the rear 5" diameter pipe) that provided a 3" lift.  Is the strut extension providing the additional 1" of lift?
You also mentioned that the toe-in was corrected with your strut extention, what did you do for toe-in when you installed the longer struts?
Rod
Rod
Offline 1bigtracker
  • 3409
Re: HEY WILD!
« Reply #38 on: March 29, 2004, 01:16:12 PM »
well its all going to get changed soon anyway so i will just wait till i lift it and rotate the axle.
stu
Re: HEY WILD!
« Reply #39 on: March 29, 2004, 04:30:28 PM »
Rod
The front spacer is 4" total length, 2" in the spring (to hold it)
and 2" out to give lift, in the front of a Track/Kick 2" gives 3"
wheel movement down, it's a compound leverage thing  ;)
The rear is 3" Dia pipe, 5" long 2" in the spring, 3" out for lift,
both front and rear are the same Dia. Pipe
The strut extensions are 3" also, and they correct Camber, not Toe-In
Toe-In is adjusted at the tierod end. The struts are stock length, tho
I'm playing with the Idea of longer custom struts to give better travel.
I'm also working on a new front CV/axle assembly that will increase the
lift from 3" Max which is limited by the CVs angle and the Cup, to 4" or 5"
with an increased angle of 15* more angle, stock CVs can go about 25*
angle these will be able to go 40* angle and not bind, so down the
suspension goes, with out the ill side effects of over extended CV cups
and bent wire retainer rings.
I'll keep you all posted
Offline 1bigtracker
  • 3409
Re: HEY WILD!
« Reply #40 on: March 30, 2004, 07:05:34 AM »
what about A arms?  those might be a big seller.
stu
Re: HEY WILD!
« Reply #41 on: March 30, 2004, 04:24:48 PM »
The A-arms I am going to build will
be wider than stock, and will work with
the new CVs and Axles, should give
about 30-40% more lift than the current
lifts that are available.
Offline 1bigtracker
  • 3409
Re: HEY WILD!
« Reply #42 on: March 31, 2004, 07:04:49 AM »
oh sweet!  i like that'
stu
Offline track_this
  • 332
Re: HEY WILD!
« Reply #43 on: March 31, 2004, 01:31:07 PM »
looks like we will all be awaiting that. that is most definently one thing all of us need.  more lift!!!. well keep us posted and you are my idol :P
shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
  • 2210
Re: HEY WILD!
« Reply #44 on: March 31, 2004, 01:38:24 PM »
Wow, sounds killer....we'll all be waiting.
