transfer case
  • 2537 Views
transfer case
« on: March 06, 2012, 05:46:40 PM »
can you swap any other transfer case for a 84 Suzuki samurai and other transfer case match
Offline Boxcar
  • 936
Re: transfer case
« Reply #1 on: March 07, 2012, 06:23:23 AM »
Do you mean any Suzuki transfer case????
 Any Samurai T-case , yes.
The 84 should have a shaft brake . Later ones may not....Boxcar
God Bless
Re: transfer case
« Reply #2 on: March 07, 2012, 07:17:00 AM »
The 84 should be a SJ410.  Which, as stated, has an ebrake mounted to the rear of the tcase.  While you can swap in a samurai (SJ413) tcase, the tcase gear ratios are not the same between the two.  So that will throw your gearing off a little.  SJ413 tcases have a 1.409 high ratio and a 2.268 low ratio.  I don't recall what a SJ410 tcase has for ratios...but I know they are different.
Re: transfer case
« Reply #3 on: March 07, 2012, 08:38:52 AM »
thank you and can you use any other make transfer case with out switching everything?
Re: transfer case
« Reply #4 on: March 07, 2012, 08:41:38 AM »
No.  Not that I am aware of.
Offline Boxcar
  • 936
Re: transfer case
« Reply #5 on: March 11, 2012, 08:26:03 AM »
Yes as long as it is a divorced transfer case passenger side drop. Dana 20s work well. as do the Dana 300.
The 20 can be regeared (Terra low kit) without changing the High range gearing : as it is a pas through T case. ( very nice )
And is absolutely bullet proof.
You will need some fab skills to do the swap: Mounts, drive line adapters , linkage , etc. Not a huge conversion......Boxcar...
PS: there inexpensive. A guy here in Astoria has 3 20s 1 divorced and 2 married for $350 for all 3....
God Bless
