95 KICK D.S. DOOR HANDLE
NY_SIDEKICKER
2274
YOU WANNA RACE THE ZUKE !
April 03, 2004, 03:15:08 AM »
OK OPENS FROM OUT SIDE BUT NOT INSIDE
STARTED AS HAVING TO PULL HANDLE 2-3 TIMES FOR IT TO OPEN FROM THE INSIDE NOW NOTHING
ANY THOUGHTS .......THANKS IN ADVANCE FOR YOUR COMMENTS & HELP
MATTY D.
http://www.cardomain.com/id/nysidekicker
http://community.webshots.com/user/nysidekicker
25
Re: 95 KICK D.S. DOOR HANDLE
April 03, 2004, 05:21:51 AM »
There is a little flemsy bar that runs from the handle to the latch. It has probably bent through years of use. I also had the plastic peice break that the bar attaches to. Pop the door panel and check it out, both are easy replacements.
NY_SIDEKICKER
2274
April 29, 2004, 01:52:53 PM »
OK FIXED MY DOOR HANDLE .......ALL IT TOOK WAS TO LUBE UP THE LATCH & STUFF
IMAGINE THAT ...SIMPLE FIX...THATS A 1ST FOR ME.......USUALLY ITS THE MOST COMPLEX PROBLEM THAT HARDLY EVER HAPPENS . THAT HAPPENS TO ME
MATTY D.
