Lift and tires(probably for Mike)!
  • 19 Replies
  • 4750 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: April 18, 2004, 01:46:28 PM »
How are the minimum lift do you need to run 35" tires?
Fender's trimming are not a problem.
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline 1bigtracker
  • 3409
Re: Lift and tires(probably for Mike)!
« Reply #1 on: April 18, 2004, 02:02:04 PM »
i will be running 35's(if not bigger) in the some time in the next few years and this is what i have come up with as a easy way to do it.
Calmini 6in lift
move floors back
trim fenders and bumpers all the way
that is just an easy way to fit them.  i'm sure their will be rubbing probs. so extra work will be needed.
stu
Offline Fredo
  • 416
« Reply #2 on: April 18, 2004, 02:11:14 PM »
Thanx Big!!!
But i think that i'm very bad in english :-[
If everybody here correct my english mistakes, i will learn more about english to communicate on this forum.
Just to reply and says what are correct and what are not.
Thanx
Fredo
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #3 on: April 18, 2004, 02:14:19 PM »
I think your looking for info on a kicker but here's my sammy on 36's with 4" spring, 6" leafover and 2" folding shackles.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline jagular7
  • 1026
  • Jagular7
« Reply #4 on: April 18, 2004, 02:42:03 PM »
Fredo
You are wanting to do this on your Kick, Tracker or Vitara? Well, all are basically the same, however, the Vitara, if similar to the US model, won't have a steering box, but will be rack and pinion. This makes it harder for a body lift. Currently Calmini, well BlackKnight, is taking names for a body lift for the XL-7, which is the long version of the Vitara.
To fit such a large tire, I'd suggest that you overlook the need, the added expense of running such a size, and the setup details to get it to that point.
Mike Hagen has done a lot of work on his personally to be able to get his to run on the 35's. He's got a custom front axle, custom rear axle, custom mods to the Calmini lift, gears, drivetrain mods, etc. He didn't install it in a weekend. It probably took him years to configure his Trackick the way it is now. And probably he'll be the first one to state it's not finished.
Basically what I'm really saying, it's not going to be easy, cheap and done rather in short time.
Lenexa, KS
Offline Fredo
  • 416
« Reply #5 on: April 18, 2004, 02:56:01 PM »
4"+6"+2"=12" of lift  :o it's very high!
Yeah i i talk about trackick, vitara... but your sami look very good!
And for jugular7
I think about 35" but a 33" will be a good idea too.
And i want to run it easily with the lowest lift  as possible between 6-7 inchs not more.(my girlfriend are just 4'11" tall 100lbs. HUMMMM she are so cuuuute  ;D)
And i don't think that i can make this in one day, a couple of week or month probably.
Fredo
« Reply #6 on: April 18, 2004, 10:26:13 PM »
I have the calmini 3" suspension and 3" body, with floorboards moved back, fenders trimmed, Hagens rear axle rotation and front end widening done. I have plenty of room for 35's on my Kick set up like this. I stayed with 33's when I bought new tires for Moab because I did not want to snap rear axles and CV's.
Offline Bfunk
  • 406
« Reply #7 on: April 19, 2004, 03:09:23 AM »
I run 35x14.50 boggers on my 93 4 door kick.  i have the Calmini 6 inch combo, 1" spring spacers for an xj, and a little trimming.  I also run 2" backspaced wheels.  Easy to fit the 35's, and I'm surprised how well the rig does with an open front end.  I think it's due to how well the Calmini system works off road.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: April 19, 2004, 03:13:51 AM »
We wouild say:  Let me know what is correct, and what is not.  You're doing pretty good!  Of course, a lot of the people who post here aren't much better at English than you, and they grew up speaking English!   ;)
I'll take a look at some of your other posts.  :D
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: April 19, 2004, 03:18:13 AM »
Let's see, we might say:
My girlfriend IS just 150 CM tall and 45 Kilos, and she is HOT!
OK, most USA folks do not understand CM's and Kilos, but your girlfriend is TINY!  (and where are the photos?)
Bob
Offline explosivo
  • 3157
« Reply #10 on: April 19, 2004, 06:46:21 AM »
What the hell are those crazy numbers that you wrote ???
;D
omghi2.us[/url]
Offline Fredo
  • 416
« Reply #11 on: April 19, 2004, 06:49:50 AM »
I love this girl so much, but i don't have pic of them. :'(
Thank you very much Bob for your encouragement.
And why i need to use IS and not ARE?
If you can understand what i realy want to say, is perfect.
Thanx
Fredo
Offline explosivo
  • 3157
« Reply #12 on: April 19, 2004, 06:53:54 AM »
IS describes one subject... for example:
"The pan is hot."
ARE describes more than one subjects... for example:
"Those pans are hot."
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #13 on: April 19, 2004, 07:18:48 AM »
 If you are thinking seriously about running that big of tire on the kick, look at the pics of Heather's SAS conversion.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Fredo
  • 416
« Reply #14 on: April 19, 2004, 09:10:33 AM »
I want to stay IFS!
;D
Fredo
