horrible fuel consumption!
  • 10 Replies
  • 3104 Views
Offline juggster
  • 119
  • No lowriders here!
« on: April 19, 2004, 09:54:19 AM »
hey guys i am getting reallly sucky fuel consumbtion on my '93 4 door 1.6ltr vitara, i calculated i am doing about 16mpg, and here fuel is costing me about $0.91 per litre, so it is costing me about $5.08 per day to drive this thing! any idea on what should be checked?
Offline 1bigtracker
  • 3409
Re: horrible fuel consumption!
« Reply #1 on: April 19, 2004, 09:57:17 AM »
THE CAT!  i am almost sure of it.  you can eather gut it out if you don't have emissions(sp) or buy a new one.
stu
Offline Mike71
  • 1449
« Reply #2 on: April 19, 2004, 10:16:18 AM »
hey stu..id kinda steer away from telling people to gut the cat of a street drivin car..since the cat really does help to cut down on the pollution a car puts out
im not a eco nazi or anything both of my dads cars probably get 9-12mpg..but they do still have cats when drivin on the street
Offline jerryp58
  • 449
« Reply #3 on: April 19, 2004, 10:16:27 AM »
The CC is a possibility, but I'd think you'd see diminished performance too if the CC was clogged.
What condition are the normal tune-up items in?
air filter
fuel filter
pcv valve
plugs
wires
cap & rotor
Jerry
Offline juggster
  • 119
« Reply #4 on: April 19, 2004, 11:20:54 AM »
i don't have a cat in it. I have just changed my sparking plugs, oil is still ok, air filter is ok, just changed my diff oil, i need to check the filters, but i think those are ok too. I am gonna check my sparks now, to see if i am running it too rich, and the i might have the injector system looked over
Offline Brandon
« Reply #5 on: April 19, 2004, 12:33:31 PM »
o2 sensor
Offline juggster
  • 119
« Reply #6 on: April 19, 2004, 06:42:34 PM »
where is it? is it easy and cheap to replace? how do you tell if it is worn out?
Thanks, and sorry for all the noob questions
« Last Edit: April 19, 2004, 06:45:12 PM by juggster »
« Reply #7 on: April 19, 2004, 06:44:05 PM »
Offline juggster
  • 119
« Reply #8 on: April 19, 2004, 06:47:59 PM »
is it a diy job?
Also what is the purpose of the O2 sensor?
« Last Edit: April 19, 2004, 06:48:32 PM by juggster »
« Reply #9 on: April 19, 2004, 07:08:03 PM »
Yes, it's easy, takes a special socket
sometimes, old one screws out and
new one screws it, it's in the exhaust
system. When the O2 sensor gets hot
it tells the computer if the fuel mixture
is too rich, too lean or just right, so it just
helps the computer to know what is needed
for fuel. With out it working the computer is
blind, so it goes into a closed loop which
is a rough aprox amount of fuel so your
engine will run, but not deliver the good
fuel mileage it could if it could go to open
loop and adjust the mixture.
Offline juggster
  • 119
« Reply #10 on: April 19, 2004, 07:09:54 PM »
where is it in the exuast?
