Technical Discussion - Performance / Modify
Should i worry?
Should i worry?
87Suzi
156
3
Love this little thing!
Should i worry?
March 13, 2012, 12:32:28 PM »
I installed my new shackles and when I tightened them down they started to bend in a little so I loosened them and just got them tight enough to hold. I haven't driven it yet but I was just wanting to make sure it's OK before I drive it.
tuxblacray
930
20
Building a Bigger Better Brute Samurai.... B-}
Re: Should i worry?
March 13, 2012, 06:35:20 PM »
Fine as Frog Hair Split 4 Ways.......
I know the voices aren't real.... but they have some pretty kewl ideas!!! Tux..... ;-)
I get my Sammi parts here, and you can too...
http://www.mikodaindustries.com/http://stores.ebay.com/sticksnstones4x4samuraiparts
swanson
55
89 chevy tracker
Re: Should i worry?
March 14, 2012, 01:09:00 AM »
That's how i have always done mine. I use nylocks and check them occasionally though.
87Suzi
156
3
Re: Should i worry?
Reply #3 on:
March 14, 2012, 09:28:42 PM »
Well I've driven it about 30mi +/- and they seem to be holding up. I like how much clearance I gained off a 1.5" shackle lift. It really did a lot for stance too. Clears my little 28" tires and then some but they fill it up and makes it look like I'm running 31s haha
1samI
8
Re: Should i worry?
Reply #4 on:
March 18, 2012, 11:07:23 AM »
I just installed shackles too! Never done any suspension mods but it pretty basic .. I bought new bushings and they have a sleeve that prevents over tightening. My shackles were homemade and 1 1/4 longer than stock this picked me up off the bumpstops and leveled off the vehicle. I just installed 225 75 15s as well I am happy It gives me very minor changes and a better ride. No noticible differance in gearing. The Rims and Tires were loaned to me. so I spent only a very small amount of money and I get to try it out for a while to decide. I think this might be as far as I want to take it, because I dont want to put say 31s on here and need to cut this and that put springs and then Ill need gears stronger axcell or bigger motor.
Any way if You dont have a sleeve you need a nylon loch or perhaps a nut with a locking cotterpin. because you cant make them tight or you will bend the shackel
87Suzi
156
3
Re: Should i worry?
Reply #5 on:
March 18, 2012, 11:13:18 AM »
I used GRADE 8 nuts and bolts, on the top bolt I used a lock washer and a self locking nut, on the bottom bolt I just went with the lock washer and a regular nut. It's all grade 8 so I know that the bolts will at least hold up
