Rear brake bias delete?
  • 1934 Views
Offline BeercityTracker
  • 40
« on: March 20, 2012, 12:33:49 AM »
anyone on here ever delete the rear brake bias valve in the rear of their trackkick, mine is leaking all over the place by it. kind of thinking of running the two lines into a block and run just one line to the rear hose. just wondering if anyone has had any issues with doing this?
Offline talonxracer
  • 1284
Re: Rear brake bias delete?
« Reply #1 on: March 20, 2012, 05:34:10 AM »
I run with mine disconnected from the upper third link and have had zero issues with braking. It is a load bias valve for adjusting brake bias based upon vehicle rotation during braking.
I did toss out the weak sauce stock front 2dr rotors and calipers for the far beefier 4dr units as the braking with 31's was downright scarey with stock brakes.
  • 40
« Reply #2 on: March 28, 2012, 06:22:58 PM »
thanks im just about to hopefully bypass it because going through a quart of brake fluid a month is getting old real fast
 :'( >:( ;) ??? :P
