Which OTT or OTS would you/have you gone with?
  • 14 Replies
  • 5779 Views
« on: March 20, 2012, 03:41:30 PM »
Lowrangeoffroad offers this...
and rocky-road.com offers ths...
Which would you go with?  Note the different mounting styles.....
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Which OTT or OTS would you/have you gone with?
« Reply #1 on: March 21, 2012, 02:13:32 AM »
Depends on what you want and how much you wanna spend. Full hi-steer some say is the best and the way to go for the ultimate in steering control. It gets your tie rod above the axle.
1/2 hi-steer accomplishes good results in steering control but leaves the tie rod in the OEM position.
If you were a rock crawler the full hi-steer makes more sense to me. As a mud runner then mayne not as much.
« Last Edit: March 21, 2012, 01:10:26 PM by tuxblacray »
« Reply #2 on: March 21, 2012, 07:08:08 AM »
See that "Z bend" in the Rocky Road kit - that says "poor design" to me - the Low Range one may or may not be better, I'd have to see the angle of the drag link with it installed to be sure, but the Z bend in the Rocky Road kit will cause bump steer (or more bump steer).
« Reply #3 on: March 21, 2012, 07:57:54 AM »
I know the one pic doesnt have the full hi-steer but i would get the whole kit.  What worries me is the mounting points of the two kits are different.  Lowrange looks to be held on at each end by two bolt holes where the rockyroad looks to go in over the knuckle and has the two bolt holes.  Good point about the z bend!  Gonna order lowrange this pm unless anyone else thinks other wise.....
Oh another thing that worries me is that at rockyroad they ask for the amount of lift to determine the the length of the steering arm yet at lowrange they dont.....
« Last Edit: March 21, 2012, 08:01:05 AM by williamb81 »
« Reply #4 on: March 21, 2012, 09:42:07 AM »
Well - I went to the LowRange site and found this...
Do you see the angle the drag link is at - that's just as bad as the Z bend in the Rocky Road kit - from a bump steer point of view.  Of course the picture was taken with the suspension at ful droop and not with the weight of the vehicle on it.
Ideally you want the drag link as close to horizontal as you can get it with the vehicle at "normal ride height" - either by raising the steering arm on the knuckles (hence the term hi-steer) or lowering the end on the steering box
« Last Edit: March 21, 2012, 09:45:20 AM by fordem »
« Reply #5 on: March 22, 2012, 12:09:30 AM »
That rig in the picture is at full droop with folding shackles.  When sitting on the tires it is probably lined up properly.
I used the Sky Manufacturing kit for years and never had a problem.  Just had half a high steer, it worked fine other then bending a tie rod on a stump during a speed run during a 4x4 comp.
« Reply #6 on: March 22, 2012, 08:45:52 AM »
Drone - correct me if I'm wrong - folding shackles pivot in three places rather than two?
If I'm right on that, I suggest you take a closer look at the picture - the top of the shackle looks to me like it's attached to a fairly substantial box section welded to the frame.
Yes - it is on full droop as I acknowledged earlier.
« Reply #7 on: March 22, 2012, 09:06:02 AM »
Looks like I didn't look closely enough last night.  Your right, looks like they built an extended front shackle mount.  I just saw the two bolt setup on top and figured it was a folding shackle rig.
« Reply #8 on: March 22, 2012, 09:09:28 AM »
Not one solid answer on the mounting points, just a bunch of im right you are wrong bs.  Big thanks for that, lol!
Offline mrfuelish
  • 2862
« Reply #9 on: March 22, 2012, 09:50:52 AM »
The sky kit bolts up to the caliper Bolts, if you break those you are really doing something, I had the rocky road kit and sold it first thing on modifying my rig to make it safer.
« Reply #10 on: March 22, 2012, 09:53:27 AM »
Wow thanks man!!  ordering now, appreciate ya!
Offline mrfuelish
  • 2862
« Reply #11 on: March 22, 2012, 10:02:56 AM »
http://www.puresuzuki.com/hi_steer_system.htm No problem, I picked up a camini full high steer not too long ago and have not installed it yet but it is going on an off road only rig and it has to have 2.5 inch offset wheels to run it, this is one heavy set up and it has six mounting points.
« Last Edit: March 22, 2012, 10:06:54 AM by mrfuelish »
« Reply #12 on: March 22, 2012, 10:18:18 AM »
At that price i should get CALMINI, its 329.95 compared to Sky at 365.00, hmmmmmmm
........back ordered for 3+ weeks :(
« Last Edit: March 22, 2012, 10:30:50 AM by williamb81 »
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #13 on: March 22, 2012, 12:35:35 PM »
Two words.... Mercedes Arms....
Bolt to caliper mounts.... can make full highsteer for less that $100.00
Just Sayin....  ;)
« Reply #14 on: March 22, 2012, 02:46:02 PM »
Just Sayin....  ;)
I dont know why those two words sound so familiar, lol.  I went ahead and ordered the sky ots, eff it ;)
