oh god not the front end again...
  • 17 Replies
  • 4323 Views
Offline talonxracer
  • 1284
Re: oh god not the front end again...
« Reply #15 on: April 06, 2012, 08:26:40 AM »
I believe a solid lock front makes steering hard/impossible under some situations off-road.  You might have to get out and unlock your hubs to make some tight bends, and then you'd only have 2WD to get round them.
There is a simple solution to that, twin sticks, just slip the TC into 2wd and the turn radius is back on the trails.
Offline IanL
  • 466
« Reply #16 on: April 07, 2012, 01:59:43 PM »
I agree that's easier than getting out to to unlock the hubs, but you are still left in 2WD when the only point in locking the front diff is to get better 4WD.  It's self-defeating.
Offline bush buster
  • 263
« Reply #17 on: April 08, 2012, 06:53:01 AM »
Ok thanks Ian... i definately need to be able to turn in 4x4...
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
