Gimme a brake.
  • 2135 Views
Offline djjiz
  • 48
Gimme a brake.
« on: April 04, 2012, 07:24:38 AM »
New guy with a new problem.
1994 2 door 4x4 with a TB 1.6 and 123k miles. No ABS.
I lose vacuum assist in my brakes periodically. Usually at highway off ramps. When it does work I gain rpms when the peddle is pushed firmly.
New front pads/ rotors/ fluid and rear shoes are 60% or more.
Brake light has been on since I bought this and only goes off when I hit a good bump so I'm assuming rear springs are weak but I'm no mechanicologist.
Any suggestions before I throw a new booster and master on it?
« Last Edit: April 04, 2012, 07:36:43 AM by djjiz »
I'll kiss your moms dildo for $10
Offline talonxracer
  • 1284
Re: Gimme a brake.
« Reply #1 on: April 04, 2012, 07:45:22 AM »
Check the vacuum line to the booster and it's one way valve.
Sounds like the switch for the brake pedal switch needs to be adjusted for the brake light issue
Offline djjiz
  • 48
Re: Gimme a brake.
« Reply #2 on: April 04, 2012, 07:53:04 AM »
Every vacuum line is new but I'll try the one way valve.
Offline djjiz
  • 48
Re: Gimme a brake.
« Reply #3 on: April 04, 2012, 07:15:53 PM »
Is the one way valve located in the line itself?
Offline djjiz
  • 48
Re: Gimme a brake.
« Reply #4 on: April 04, 2012, 07:39:13 PM »
Answered my own question..
So.. Now that I threw the check valve away what kind of replacement can I use and how much damage could I have done? Ive been driving without it for 1000k miles atleast.
Offline talonxracer
  • 1284
Re: Gimme a brake.
« Reply #5 on: April 04, 2012, 08:22:07 PM »
Just get a new one, shouldnt be any issues then.
