1997 suzuki vitara/sidekick
  • 2360 Views
Offline fleX90
  • 11
« on: April 06, 2012, 09:18:01 PM »
Hi, can anyone tell me or post a picture where the check engine light reset switch is? ive look all around the steering colum and around the speaker but cant find it. any help would be appreciated
Offline fuzzy1
  • 350
Re: 1997 suzuki vitara/sidekick
« Reply #1 on: April 07, 2012, 05:37:04 AM »
On a US version '97 (OBD2) there isn't one. They were only on the earlier OBD1 versions. You can reset it by removing the dome fuse or disconnecting the negative battery terminal for a minute. But, you should get a scan tool & retrieve the codes 1st... just clearing the code won't fix it.
Non Illegitimi Conterat
« Reply #2 on: April 07, 2012, 01:41:56 PM »
The SES switch was only on US models so if its a Vit then it won't have one.
Offline fleX90
  • 11
« Reply #3 on: April 07, 2012, 06:15:18 PM »
Thanks for the help, i was wondering why i couldnt find it  :-\ haha. Ive tried 3 scanners to try get the code but none pick up the computer so i have to go to genuine suzuki dealer to get it scaned. I was gona reset it and see if the fault would come back on, Im pretty sure the fault is either a O2 sensor or air flow meter issue. thanks again for the help
