steering play
  • 3265 Views
steering play
« on: April 08, 2012, 05:48:05 AM »
My steering  has never been tight  on my 87 sammy with  31" tires , even though it has A drop pitman arm with new tie rod ends and drag link for high steering .The steering wheel has play, if I held my hand at 12 o'clock I could turn it to close to 2 o'clock and back to almost 10 o'clock without moving the  wheel . What can be done to tighten it up and get a more direct feel?
Offline airdale navy
  • 82
Re: steering play
« Reply #1 on: April 08, 2012, 08:40:41 AM »
If it is like the sidekick,there is a nut on top of the steering box .With a stud with a screw slot .Hold with a screwdriver and break nut loose.Turn in clockwise.Then re-tighten holding  with the screw driver.Turn about 1/4 at a time and recheck.Do not over do it.
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Offline Jonny Rash
  • 1094
  • 21
Re: steering play
« Reply #2 on: April 08, 2012, 08:56:10 AM »
As Airdale stated, that is the way to adjust the free play in the steering box. Years ago I read that you need to have a friend turn the steering wheel as you remove the freeplay at the box, otherwise you can possibly damage the box. I believe that it can bind, if you don't crank the wheel while it is adjusted.
Also, check the steering coupler. Unbolt it and inspect it for tears. I recently had one that was literally ripped throughout, but it was not visible with it installed.
A panhard bar will also help a lot.
Re: steering play
« Reply #3 on: April 10, 2012, 12:35:48 PM »
Thanks Airdale for the right advice , I put just a tad more than a 1/4 turn and all is well with my steering no more white knuckles. Also it would probably be a good time to check and  top off your steering box oil.
Re: steering play
« Reply #4 on: April 10, 2012, 01:11:06 PM »
Very timely thread. I was just thinking about doing this on my 'Kick.
- Andy
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Re: steering play
« Reply #5 on: April 10, 2012, 02:43:04 PM »
I've been wanting to replace the ragjoint in my steering for a long time but the hardware seems to be frozen, couple that with the turbo sitting right there and I just keep ignoring it. I know it needs attention, just need to get on it. Thanks for the good tips on steering adjustments.
  • 82
Re: steering play
« Reply #6 on: April 10, 2012, 04:25:10 PM »
Glad I could help.
