Tranfer case rebuild... it is cracked?
  • 2892 Views
Offline zuki1018
  • 397
« on: April 08, 2012, 05:23:01 PM »
Heres a close up:
I dont see the same cracks on the outside but there is definitely fractures/cracks visible.  I probably should be looking for a new case right?
TIA
Re: Tranfer case rebuild... it is cracked?
« Reply #1 on: April 09, 2012, 02:54:24 PM »
Not necessarily. I saw some similar " cracking" in on the inside of my t case and I believe they are just from the casting process. I don't think these are die cast, more like sand cast, and those are just normal flaws. Gotta say though, there's a few more in yours than mine. Wouldn't worry about it too much.
Offline lv2fsh
  • 312
  • 19
« Reply #2 on: April 09, 2012, 06:05:48 PM »
I have seen what looks like cracks too. I think they are normal like was said. There is no pressure in the case so unless they are leaking out the cracks, I wouldn't worry.
Offline talonxracer
  • 1284
« Reply #3 on: April 09, 2012, 06:21:30 PM »
I know exactly what you have seen, I have seen them many times as well. I was told it is a spot where the liquid aluminum didnt flow uniformily going into the mold.
But I would double check just to make sure, there seems to be alot of them radially from that pocket.
« Reply #4 on: April 09, 2012, 09:11:27 PM »
Those "veins" are completely normal.  Every zuk tcase I have had apart has had them.
Offline zuki1018
  • 397
« Reply #5 on: April 10, 2012, 04:45:42 AM »
Thanks for all of the responses.
