31x10.50TSL on trackick
  • 24 Replies
  • 5773 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: April 14, 2004, 04:51:33 PM »
OK guys I just bought these tires but the front wont fit.  >:(I was thinking of buying the calmini 3" susp. lift and I need to know if they will clear. I now have some home made spring spacers which yield about 2" of lift. the tires are tsl 30x10.50 w/2.75" back spacing need help.
      thanks
                Kevin
Offline 92Sidekick4x4
  • 1456
Re: 31x10.50TSL on trackick
« Reply #1 on: April 14, 2004, 05:03:05 PM »
I think i remember Kreg telling me once that he rolld around with 31's on his kick when he was in the middle of doin his lift and he only had the 3" suspension.
i may be wrong tho, kreg?
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #2 on: April 14, 2004, 05:08:29 PM »
Offline explosivo
  • 3157
« Reply #3 on: April 14, 2004, 05:10:25 PM »
I rolled around on my 33's for a few days after I did my body lift and was waiting for my Calmini 3" suspension lift. It did require a bit of cutting and hammering to turn the wheels all the way without rubbing, though.
omghi2.us[/url]
GRVIT
« Reply #4 on: April 14, 2004, 09:46:06 PM »
well,I have 3" Calmini susp.lift,3 " Calmini body lift and two days ago I replaced the 30X9,5X15 Yokohama Geolandar M/T with 31x10,5x15 Fedima Extreme(retreaded).
http://www.fedima.gr/site2/prod4x4.html
The Fedima Extreme is like the Yokohama with the outer teeth are bigger.I had some rubbing to the front bumber (when wheels are turned) as well as to the back of front fenders.I cut the stock bumber a bit and did a bit of cutting to the fender.Now its o.k. Ah...the Fedima are on 15x8 rims,3".
« Last Edit: April 14, 2004, 09:47:07 PM by GRVIT »
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: April 14, 2004, 11:21:41 PM »
GRVIT, How did you like the Yokohama M/T? I've been looking at them and have heard some good things.
« Last Edit: April 14, 2004, 11:22:19 PM by cj »
GRVIT
« Reply #6 on: April 14, 2004, 11:47:39 PM »
The Yoko Geolandar M/T 's are very good.Soft and not heavy(important).Better than BF or GYear when it comes to weight and softness.I would put now the 31x10,5x15 Geolandar instead of the retreaded ones but since its summer ahead I didnt want to use  now so expensive tires.Most possibly I will put them on after October.
They have good grip even on ice.The fact that they are soft helps in this case.At last I ve done aprox 10.000 miles with them (rocks,mud,e.t.c) ,they lost aprox 0,15" of rubber.And I never had a flat tyre.
« Last Edit: April 14, 2004, 11:52:18 PM by GRVIT »
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #7 on: April 15, 2004, 10:34:41 AM »
i have a calmini 3" body lift and i use to run 31 swamper ltb with a little trimming.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline 1bigtracker
  • 3409
« Reply #8 on: April 15, 2004, 01:50:42 PM »
WOW those retreads are sick!  i'd almost give up my swampers for those.
stu
Offline Speedracer7c
  • 2210
« Reply #9 on: April 15, 2004, 01:56:33 PM »
Those are awesome.....how much is shipping from east bumfuckinindia
Offline Bfunk
  • 406
« Reply #10 on: April 15, 2004, 03:30:42 PM »
Is anyone running a tire that is big enough to take you off road or are you all just going a little bigger than stock.  I was looking for some people with bigger meats under the fenders.
Brian
GRVIT
« Reply #11 on: April 15, 2004, 04:42:51 PM »
well  ,yes sorry.For the Fedima Racing Tires (made in Portugal) try this link
http://www.recauchutagem31.pt/gbhtml/home_gb.html
The Fedima Partner is like the Extreme,except the fact that the first is considered to have stronger sidewalls.Basically,they are the same.Pricing is good.
Hope this helps.
« Last Edit: April 15, 2004, 04:50:00 PM by GRVIT »
GRVIT
« Reply #12 on: April 15, 2004, 04:50:59 PM »
What do you mean Speedracer7c..........?
Offline zukalaska
  • 14
  • Don't worry thats Normal.
« Reply #13 on: April 15, 2004, 10:32:30 PM »
I know its sounds like alot of BS but I'm running 31-10.5 15 on my stock no lift samurai.  ??? i dunno. Jess
Keen Sense, Common Sense and A Whole Lotta Nonsense :)
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #14 on: April 16, 2004, 12:58:35 AM »
Brian
??? My 205x75x14s took me everywhere for a while...  :P I was just short on ground clearance... So gradually... over a few years...
..... but what about Mike? He's running.. I think... 35's?
But... I have seen some serious crap with smaller tires...
...So what do you mean by running tires "big enough" to take you off road? It's all the state of mind  ;D
Heather
Heather Galvin
