Fuel injection
  • 2083 Views
Fuel injection
« on: April 12, 2012, 12:42:53 PM »
When did Suzuki start putting fuel injection into the Samurai?  I have a 88 and have found an 88.5.  I have not got to look at it yet.  If it is stock will it have fuel injection?  Why two different models for the same year?
Re: Fuel injection
« Reply #1 on: April 12, 2012, 01:18:20 PM »
1990    - removed two of four spider gears from front differential
- wheelbase increased an inch or two (inorder to improve the ride)
- added FI (fuel injection) to 1.3L engine, increased horsepower to 66
- tranny and tranfer case bearings changed to the sealed design
Offline airdreams1
  • 90
Re: Fuel injection
« Reply #2 on: April 12, 2012, 01:26:13 PM »
this link should give you all the info you need.....
http://en.wikipedia.org/wiki/Suzuki_Jimny
87 Samurai  soft top
Re: Fuel injection
« Reply #3 on: April 12, 2012, 07:57:07 PM »
1990 is correct for the first year for EFI.
Suzuki actually removed 2 of the 4 spider gears in the front carrier in 88.5s (although 88.5s were generally a mix and match of parts....so some had 2 spider gear front carriers and others had the older 4 gear style).
The wheelbase never changed....it is 79.9"....86-95 samurais.  They did change the rate of the rear springs at some point though, to improve the ride (I think it was in 88.5).
Wikipedia is generally a pretty good source of accurate info.  But it isn't always true.  For example, they say, "A new 1.3 4-cylinder engine with throttle-body fuel injection was introduced with 66 hp (49 kW) in September 1991."  Which is obviously wrong.  The 1990 model year samurais were the first ones with throttle body EFI.
