xfercase differences
  • 9 Replies
  • 3659 Views
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« on: April 29, 2012, 08:28:24 PM »
 I found a great deal on a xfercase from an 89-95 auto trans Kick. will it work on a manual trans Kick ?
             Ed
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Offline biker
  • 730
  • It's a sickness I tell ya
Re: xfercase differences
« Reply #1 on: April 29, 2012, 08:50:36 PM »
Yes, bolts right up
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #2 on: April 30, 2012, 05:28:36 PM »
The only difference in them is the speedo gears in them.  Your speedo won't read right, if you swap a tcase in from a trackick that had different axle gears than your current one (if the tcase is from a 4 door with the auto, then it would have had 5.12 axle gears, which is what your 5 speed trackick likely has).
That is also assuming your trackick is an 89-95 (89-95 trackick tcases have a 26 spline rear output shaft....96 and up tcases have a 16 spline rear output shaft).
Offline FireCkrEd
  • 246
« Reply #3 on: April 30, 2012, 07:08:43 PM »
 Thank you Sky, I jumped on it since mine needs a re-build. The guy said its for an 89-95 so I figured it would fit but it does have 16 spline output shaft.... Sky got any 95 plus driveshafts ???? I still have to get my 4.24 gears in it and remove the detent ball for a twin stick so I still have a bit of work to do on it before I can use it.
                          Ed
« Reply #4 on: April 30, 2012, 07:13:57 PM »
                          Ed
I think I might have a 16 spline slip yoke around (you can swap slip yokes on your existing driveshaft).
Offline FireCkrEd
  • 246
« Reply #5 on: May 01, 2012, 05:37:22 AM »
 front and rear ? give me a price with shipping to 90731 code...
            Ed
« Reply #6 on: May 01, 2012, 06:00:26 AM »
            Ed
I am out of town right now.  Give me a day or two and I'll look to see what I have and get back to you.
Offline FireCkrEd
  • 246
« Reply #7 on: May 02, 2012, 05:56:54 AM »
 :) thank you Sky
« Reply #8 on: May 02, 2012, 10:07:53 AM »
If your tearing into the t-case to swap the gears why not just change your output shaft at the same time?
Offline FireCkrEd
  • 246
« Reply #9 on: May 03, 2012, 06:31:43 AM »
Im going to take the old case and the new one to Petroworks. They did the gears in the old one.
          Ed
