Lock right in a 2-pin carrier?
  • 2869 Views
Offline MongooseVRX
  • 64
    • M.O.S. forum
« on: May 03, 2012, 07:50:33 AM »
I am putting a lock right in my new steel front end, but the original diff has the 2 pin carrier. It doesn't seem like it'll work right. Do I need a different carrier, perhaps a junkyard rear(4-pin)?
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
Re: Lock right in a 2-pin carrier?
« Reply #1 on: May 03, 2012, 08:25:19 AM »
That would be the easiest.  When you say 2-pin, do you mean a single pin through the center?  Or does it have 3 pins, one in the center and two half-pins on both sides?
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #2 on: May 03, 2012, 08:33:47 AM »
1 pin, two spider gears. The lockright came with three pins, 1 long and 2 short. I think I will call powertrax too, see if they have any advice.
Minnesota Overland
Offline Jonny Rash
  • 1094
  • 21
« Reply #3 on: May 03, 2012, 09:24:04 AM »
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #4 on: May 04, 2012, 04:39:57 AM »
Or you could run a Samurai 3rd.
Do you think a 10-bolt(trackick pre '93) rear would fit up front?
Minnesota Overland
Offline Jonny Rash
  • 1094
  • 21
« Reply #5 on: May 04, 2012, 06:20:23 AM »
No, it is physically larger.  Get a 4-pin Samurai carrier or the modified carrier from Trail Tough.
« Reply #6 on: May 04, 2012, 07:25:37 AM »
With the samurai carrier, if you are going to 5.13 gears you have to get metal cylinders "cans" that will hold the short side pins in.  The lower gears that samurai's normally run are physically taller and will hold the side pins in place, not so with 5.13's.  ZW venders carry these "cans".
