Electrical issues
  • 13 Replies
  • 4133 Views
Offline djjiz
  • 48
Electrical issues
« on: May 03, 2012, 10:41:12 PM »
I'm hoping someone can help.
94 tracker 2 door 8v and computer caps replaced before I bought it
My horn/ tail light fuse constantly blows but they both work fine and my front turn signals work when flashing bit they won't light up with the headlights in the on position. New bulbs didn't help.
I'll kiss your moms dildo for $10
Offline Flatlander
  • 45
Re: Electrical issues
« Reply #1 on: May 04, 2012, 05:56:12 AM »
maybe a grounding problem.  I have a 93 tracker that did much of the same thing.  Checked all grounds and seemed to help my problems, but that was what worked for me.  Hope ya get it figured out
Offline djjiz
  • 48
« Reply #2 on: May 04, 2012, 07:07:02 AM »
Sounds reasonable.
I'll spend the day checking grounds. Thanks.
« Reply #3 on: May 04, 2012, 07:46:07 AM »
FWIW
I spent almost a month chasing loose connections, both power and ground.  Seems that some ground wires like to hide when you are reinstalling equipment.  And replace the worn/frayed grounds, cause they will haunt you sooner or later.  Connections that don't snap closed can be an issue also.
Offline djjiz
  • 48
« Reply #4 on: May 05, 2012, 02:22:16 PM »
Found other issues with wiring and were exactly like you said.. Frayed connections behind things I didn't wanna remove.
Fixed my dash lights and horn but still can't figure out the front corner lights.  :-\
Offline fordem
« Reply #5 on: May 05, 2012, 04:24:54 PM »
OK - let's see what we can do about those "front corner lights".
What exactly is the problem - your first post says ...
Front turn signals & front corner lights may mean the same thing to you, but they don't mean the same to me - you seem to expect, the front turn signals to flash when you're turning and light up with the headlights - Suzukis don't work that way - corner lights & turn signals are different.
Offline djjiz
  • 48
« Reply #6 on: May 05, 2012, 06:30:56 PM »
Thanks for the replies.. The lights on the fenders are working fine and I understand they don't flash.
The corner lights (to me) are the ones that flash when blinker is applied and they still work in that regard. They just don't stay on when the headlight switch is turned to any position.
Offline fordem
« Reply #7 on: May 06, 2012, 08:58:32 AM »
Unless I'm very much mistaken - there is no light on that vehicle that should both flash with the turn signals and come on in any postion of the headlight switch - it's just not how Suzuki does things.
Offline djjiz
  • 48
« Reply #8 on: May 06, 2012, 09:41:00 AM »
I appreciate everyone's patience.
See the orange lights next to my headlight? Those only light when I use the turn signal now.
Offline fordem
« Reply #9 on: May 06, 2012, 02:51:29 PM »
OK - I just found one of those lamps on ebay and the picture does show three wires from that lamp so it should light both with the park lamps and the turn signals - my apologies - get your self a test lamp and check the power to the connectors with the park lights on - one of the wires should be red/yellow (I think), you should have +12V on that with the lights on.
Also check the front light grounds.
Offline djjiz
  • 48
« Reply #10 on: May 09, 2012, 03:21:10 PM »
Problem solved!
After chasing wires for days I just went ahead and replaced the sockets the bulbs were in and BAM.. They were clean but I guess that wasn't enough.
I've managed to break the elements in every bulb except the fender lights from the property I wheel at and now I'm finding the limits in the electrical connections and my rig.
Thanks for your help.
Offline talonxracer
  • 1284
« Reply #11 on: May 09, 2012, 03:36:14 PM »
I started going thru all the grounding locations on my Sidekick, cleaning them up nice and shiney, ran taps into the grounding bolt holes, cleaned the bolts and re-installed the grounds, then coated them with a heavy duty water displacing film. This solved many annoying irrational issues, LOL
« Reply #12 on: May 10, 2012, 04:05:12 PM »
Problem solved!
My daughters 4 door was doing a crazy thing too, rear drivers side brake light was going OFF when brakes applied with lights on. Tested every freakin wire and ground, everything seemed good. After many hours I pulled a lamp socket out of a spare light I had and put it in, viola, problem solved. The old socket looked great too. weird.
Offline fordem
« Reply #13 on: May 10, 2012, 05:25:55 PM »
That's definitely a bad or broken ground - the question is where.
