87 samurai 4x4 rear axles help
  • 5905 Views
« on: May 07, 2012, 01:53:27 PM »
I'm looking for a rear axle for my 87 4x4 suzuki samurai. I don't know a lot of the techincal specs, but if they're needed to help answer my question I will get it.
I need to know what axles from other trucks are compatible with mine. Preferably with no modifications.
Any help is appreciated. Thanks!!
Re: 87 samurai 4x4 rear axles help
« Reply #1 on: May 07, 2012, 01:54:12 PM »
Are you looking to swap out the entire rear axle or just need some axle shafts?
« Reply #2 on: May 07, 2012, 04:44:49 PM »
I want to swap out the entire rear axle if I can find something that will fit. I'm hoping to find some other models that will be a perfect fit. That will open up my options instead of looking for just an 87 samurai axle.
« Reply #3 on: May 08, 2012, 05:48:41 AM »
I should have been more specific. I want to replace the entire rear end basically. Is there any rear ends that bolt up (without modification) to a 87 samurai (besides a 87 samurai)?
Offline Boxcar
  • 936
« Reply #4 on: May 08, 2012, 08:19:19 AM »
86 and newer samurai rears are all a good fit. If you need a stock geared axle.
 71 and 72 cj5 are the closest non Zuke fit. But gear matching the front axle may be required.....Boxcar...
God Bless
« Reply #5 on: May 08, 2012, 09:29:31 AM »
They are centered rear axles as well right?
You can call Trail Tough and get a cut down Toyota axle that is the same width.  You might be better off looking at swapping both axles so you can get a matching set.
« Reply #6 on: May 08, 2012, 08:32:25 PM »
86-88 samurai rear axles will be identical.  In 88.5 they changed the bolt pattern on the pinion flange (larger and used bigger bolts).  They also went from 2 rear brake lines from the frame to the axle, instead of one.
For the pinion flange difference, you can simply drill the smaller/early bolt pattern into the larger/later pinion flange.  Just use the driveshaft end for a template to mark/drill the holes.
For the brake lines, you could swap the lines from your old axle, or redo the brake lines on the newer axle.
So bottom line.....86-88 is identical....88.5-95 will take some adapting.
Offline Boxcar
  • 936
« Reply #7 on: May 10, 2012, 08:09:32 AM »
No, Drone there off set just like a Zuke.......In fact any CJ5 that ran the Dana 18 t - case will be off set to the passenger side.
 Its the later Dana 20 T - case CJ's that were centered.
 I have a set of CJ's on my deck right now being prepped for a swap. I'll get some pics posted up soon.
 They are as near a direct swap as you will find.
 4.88 gears / same width as the zuke Bigger  brakes / legendairy toughens, all for $300....
 Try to find a pair of cut down Yotas as strong and as inexpensive as Jeep axles.
Good luck with that.....Boxcar...
« Last Edit: May 10, 2012, 08:16:25 AM by Boxcar »
God Bless
