Toyota Axles
  • 2120 Views
Offline steedalx
Toyota Axles
« on: April 16, 2004, 02:37:48 AM »
Who's running toyota axles on their samurai?  I am looking to upgrade and wondered if any years work better than others.  Thanks
Offline rockrat
  • 196
  • Got Ringr
Re: Toyota Axles
« Reply #1 on: April 16, 2004, 10:54:23 AM »
79-85 are all the same with the exception of the housings. 84-85 have a truss under the axle that goes all the way under the spring pad. 79-83 stopped 1" short of that. On any Toy swap you need to raise the dr. side pad 3/8" to equal the height on the pass side. you also have to redrill the perches 3/8" inward to accomidate the spring width difference. The rear you just need to move spring pads in 1" on each side. rear brake lined are compatible, fronts you can use rear Toys for the extension and Drive shafts can be hooked up easily enough with a set of my adapters.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Toyota Axles
« Reply #2 on: April 16, 2004, 11:07:12 AM »
I heard 84's are practically bolt on. Check this.
http:// http://www.pirate4x4.com/forum/showthread.php?s=&threadid=116013
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline snakeman
  • 274
  • Alrighty Then
    • Oregon Trail 4x4 Association
Re: Toyota Axles
« Reply #3 on: April 16, 2004, 12:11:15 PM »
79-80 = 4.37 ratio
81= 3.90 ratio
82+ = 4.10 ratio
Jeff
Oregon Trail 4x4 Association - Eugene, Oregon
http://www.ot4x4.org/[/url] Come check us out if your in the Eugene / Springfield area!
87 Tin Top, 1.6 16v, 4.9, 4.62's w/ sidekick rear, TT YJ swap, custom snorkle.
Offline rockrat
  • 196
  • Got Ringr
Re: Toyota Axles
« Reply #4 on: April 16, 2004, 04:24:52 PM »
(Negative) some may just drop it in, but its not correct way of doing it. Best palce for a write up is www.azrockcrawler.com
Offline rockrat
  • 196
  • Got Ringr
Re: Toyota Axles
« Reply #5 on: April 16, 2004, 04:27:46 PM »
79-80 = 4.37 ratio
81= 3.90 ratio
82+ = 4.10 ratio
Jeff
Those ratios all depend on weather it was a auto or stick and tire size, toy all supplied 4:88 and 4:56 in the newer trucks based on auto or manual and v-6
The most common ratio is the 4:10 and 4:11
