Technical Discussion - Beginner / Repair
Good vs cheap rear sami wheel bearings?
zuki1018
397
7
May 12, 2012, 06:36:46 AM »
Just wondering where you source your rear bearings/retainers from? Local parts house is $50 each bearing only. Major Sami venders are like $40 and some others are like $12-20.
Opinions on if I should stick to a particular brand... or a price range?
Also can someone explain how the larger hole "backing plates" benefit things ? TIA
mrfuelish
2862
13
you must have a perception problem.
Re: Good vs cheap rear sami wheel bearings?
May 13, 2012, 12:11:10 PM »
well you probably don't want a 12.00 Dollar bearing, those plates are in the pic are allot easier to carry a spare axle around than having a backing plate hooked to it and you do not have to mess with the brake lines and bleed them.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
ecoast
509
8
You tube my space, and I'll google your yahoo
May 13, 2012, 01:13:34 PM »
you have to cut a section from the bracket
http://www.roadlessgear.com/html/techarticles/backingplates/index.html
Drone637
8121
116
Evil Cow
Reply #3 on:
May 14, 2012, 11:05:37 AM »
Just make my own backing plates by cutting up a spare set of drum brakes.
warbird
110
2
Reply #4 on:
May 14, 2012, 11:27:07 AM »
"Cheap" bearings will cost you far more in the end. I'm on my third set and one of them is going bad!
I'd stick with a well known brand (Timkin or National). Some of the Japanese bearings are OK but you never know. Don't cheap out on the seals either. A significant leak will eventually contaminate the brake shoes/pads (if you don't catch it soon enough).
