Muffler Question
  • 2778 Views
Offline ZukkinMad
  • 57
  • Whatcha Waiting For?
Muffler Question
« on: April 15, 2004, 01:18:33 PM »
My calmini header is on its way, and I spoke to the guys at the muffler shop today, they deal with strictly magnaflow and mentioned that the straight through design of the magnaflow would make me lose my low end torque = (take off speed)
I've been checking out the dynomax  Super Turbo's online, and flowmasters. Have you guys used any of these mufflers? I'm looking for a deep mellow tone, no loud nascar stuff.
Awaiting your recommendations
Zukk
1994 4dr Kick, Calmini 2' suspensin lift, RRO Coil Spacers front & rear, 2" RRO Body Lift, Super Swampers TSL SX, 15 x 8 black rims, calmini header, dynomax super turbo muffler & accel super coi
Offline 1bigtracker
  • 3409
Re: Muffler Question
« Reply #1 on: April 15, 2004, 01:42:35 PM »
low end torque can be made with a steped exhaust system.  if you started with like 2 feet of 2in then you could go to 2/14 or 2 1/2 and a free flow muffler and you'd be good with low end.
stu
« Reply #2 on: April 15, 2004, 05:29:10 PM »
The new truck exhaust systems have a 2 stage stepped
system, big out of the heads, reduced thru the Cat and
Muff, then large out from there, the big off the head is
supposed to work like an expansion chamber on a dirt
bike, then small for torque, then big out for good looks.
But this is on a V8 GMC, might not carry over to
a 4 cylinder as well.
Offline idaholwb
  • 772
« Reply #3 on: April 15, 2004, 05:54:26 PM »
 I've used the DynoMax Super Turbo on an AMC V8 and I loved the way it sounded! I've had a few friends use the Flowmaster with Suzuki 4 cyls, they sound pretty good.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ZukkinMad
  • 57
« Reply #4 on: April 15, 2004, 08:09:47 PM »
Which series flowmaster did they use?
Zukk
Offline idaholwb
  • 772
« Reply #5 on: April 15, 2004, 08:21:51 PM »
 Not sure which series, but one was a 3 chamber and the other was a 4 chamber. The 3 chamber sounded better. They were both the welded version.
As far as the back pressure thing is concerned, I have a 1.6 8v with a header with 2 1/2" exhaust with no adverse low end effects. The beautiful thing about how low geared zukis is how they respond to freeflowing exhaust. I've had 2" with the same motor, it works better with the 2 1/2" on the freeway especially.
« Last Edit: April 15, 2004, 08:22:35 PM by idaholwb »
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #6 on: April 15, 2004, 10:03:28 PM »
I'm running a flowmaster with 2 1/4" pipe. I have the same set up on my Kick 89 8V and my 98 X-90 16V. I noticed nothing but gaines from the exhaust. The 16V realy responded with better mileage and power commuteing 100 miles to wirk every day. My 8V also gained power with little or no torque loss. The guys at the fuffler shop told me the same thing but I had already spoken to other people that had done the same thing and they loved it. The flow master is also a great off-road muffler due to it's strong design. They are almost indestructable. My last one lasted me 7-8 years of off road abuse.
I think I am going to try out a spintech muffler this time and see how good they are. I dont know any one using one yet and they are suppost to be small, strong and perform well.
« Last Edit: April 15, 2004, 10:07:43 PM by Zukipilot »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: April 16, 2004, 04:08:38 AM »
I just put the Calmini hi-perf muffler & exhaust pipe on my 2-door (I already had the header).  It gave me a noticable increase in power.
But before I put it on, I fired up the rig with just the Cat, and no muffler.  Then I asked myself "why do I NEED a muffler?"  It just wasn't loud at all.  Some day, I'm going to try the performance of either no Cat, or no muffler, and see how they work on the road (on the trail, I'm geared so low, a 20 HP engine would probably work fine).
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #8 on: April 16, 2004, 10:50:14 AM »
For awhile now on  my sami I've been running a 3 chamber Flowmaster 2.25" with great results. I have the Thorley header with a 2.5" Catco cat into the Flowmaster. Its practically a straight run out the back so it makes a good weekend project using a little welder, aluminized exhaust pipe pieces and a couple of clamps.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
