wanted 5.12 complete front and rear thirds
  • 2950 Views
« on: June 03, 2012, 11:33:42 AM »
Iam looking for 5.12 complete front and rear thirds to buy or trade for my 4.62 from my 96 x90 with 90k miles.
Offline Khodabear
  • 155
  • Littleton Colorado
Re: wanted 5.12 complete front and rear thirds
« Reply #1 on: June 03, 2012, 02:12:40 PM »
Is there a part number I can reference?
I'm parting a '91 2 door 5 speed. Isn't 5:12 pretty much the stock ratio for that application?
1997 Tracker
1997 X90
« Reply #2 on: June 03, 2012, 02:34:45 PM »
Yes
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: June 03, 2012, 07:41:44 PM »
Don't forget:  '92 - no ABS, '97 YES ABS...
You may be forcd to use everything in the '97 Rear Diferential and swap the Ring and pinion while the Front Differential may be plug-n-play (unless they changed the sidegear spline count).
Any comments on this?
Ack
Offline Khodabear
  • 155
« Reply #4 on: June 04, 2012, 07:41:53 AM »
In that case... I just picked up a 97 Sidekick Sport 8 valve 5 speed 4 x 4  that suffered  transmission failure. In the process of trying to fix it they messed up the interior pretty bad. I have no idea how or why they got so much grease on the headliner...well...I think it's grease...anyway  I'm on the fence about trying to clean it up, fix it up and put it back on the road or part it.
So,  I might have later model thirds if that's what you'd need.
Peter
1997 Tracker
1997 X90
« Reply #5 on: June 04, 2012, 09:02:40 AM »
When you figure it let me how much.
Offline Khodabear
  • 155
« Reply #6 on: June 04, 2012, 11:16:06 AM »
I'll need a few days. I need to verify that the engine is good
1997 Tracker
1997 X90
Offline Khodabear
  • 155
« Reply #7 on: June 06, 2012, 10:30:43 AM »
Just pulled the rear third from the '91 Tracker. It has a speed sensor. Not sure if that makes a difference or not but there it is. :-)
« Last Edit: June 06, 2012, 11:12:57 AM by Khodabear »
1997 Tracker
1997 X90
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: June 06, 2012, 12:22:46 PM »
You wouldn't want mine, because they're 5.83 instead of 5.12, and have ARB Air Lockers on 'em.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
