Transmission
  • 2465 Views
Offline Sundance58301
  • 79
    • Dry Lake Farm
Transmission
« on: June 03, 2012, 12:57:41 PM »
I found a 5 spd trany out of a 1997 Tracker to
put into my '93 Kick.
Question:
Are there anythings to look at to get an idea of it's
condition?? (it's out of vehicle).
I am thinking if there is fluid in it to drain it and look
at the fluid before I buy it??
Thanks
1992 Suzuki Sidekick JX
*4 Door
*5 Spd
*16V
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Transmission
« Reply #1 on: June 04, 2012, 06:52:08 AM »
The 97 will have a different output spline than 93, you will need the drive shafts also or at least the slip yokes
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Re: Transmission
« Reply #2 on: June 04, 2012, 08:03:05 AM »
Wrong.  It is the tcase output shaft that has different splines, not the tranny.
The tcases will interchange between the trannys, so if it is 4x4, and if it comes with a tcase, just swap tcases.
  • 79
    • Dry Lake Farm
Re: Transmission
« Reply #3 on: June 04, 2012, 05:33:36 PM »
Pardon me for being a bit confused..... So the transmission will
fit up with my transfer case? Both are 4x4
*4 Door
*5 Spd
*16V
Re: Transmission
« Reply #4 on: June 04, 2012, 08:35:29 PM »
Yes.  Your tcase will bolt up to the newer tranny.
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
Re: Transmission
« Reply #5 on: June 05, 2012, 06:00:52 AM »
What Sky is saying is the transfer case from the later Sidekicks 95 ? 96 + had a 16 spline output shaft at the rear. the front shaft is the same as yours and your trans will bolt up to your xfercase.
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
