new to sidekick, but fell in love with my new little 95
  • 10 Replies
  • 3106 Views
Offline werforeman
« on: June 08, 2012, 08:12:08 AM »
Offline talonxracer
  • 1284
Re: new to sidekick, but fell in love with my new little 95
« Reply #1 on: June 08, 2012, 09:16:44 AM »
Welcome to your new addiction! LOL, same basic story here, cant leave anything stock.....first thing I did was to get rid of the carpet all together and put down Monstaliner bedliner.
« Reply #2 on: June 10, 2012, 07:50:28 AM »
I haven't seen one w/o Tach - go to wrecking yard and get another instrument cluster with tach in it.  If you want correct mileage, swap your speedo into that cluster.  The wiring is probably in yours, as same years models had different options and FSM wiring shows lots of unused points.  Worse case you will have to run a wire.
Get a Factory Service Manual, or become familar with Ack's http://www.acksfaq.com/.  He has FSM's online.
Welcome, the Water Cooler is for introductions http://www.zukiworld.com/forum/the-water-cooler/, & listing where you are helps get in contact with other riders in your area (thanks for using map).  Always list year model when listing problems.  Photo's help descriptions (and we like seeing what you are doing).
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #3 on: June 10, 2012, 08:39:36 AM »
i had an Opel Kadett back in the day; but not a GT...had a foot pump on the floor you would pump with left foot to squirt washer fluid!
Good luck with the rig.
Offline talonxracer
  • 1284
« Reply #4 on: June 10, 2012, 11:16:31 AM »
I have seen several in the salvage yard without a tach, but they had auto transmissions under them.
Offline mike5721947
  • 545
« Reply #5 on: June 10, 2012, 09:14:11 PM »
Mine came with no tach as well. swapped in a different cluster no problem
also didnt have a clock or a cig lighter in mine.
31" kumhos 3inchs of lift.
Offline werforeman
« Reply #6 on: June 11, 2012, 08:27:52 AM »
« Reply #7 on: June 11, 2012, 06:05:17 PM »
Camber bolts seem to work, if only torqued to specifications.  I had one break on me, so I am somewhat wary of them.  You can also have the strut holes slotted put a large washers on and after adjustments weld the washers in place.
Offline werforeman
« Reply #8 on: June 12, 2012, 08:59:45 AM »
 Thanks for the option, What about the back wheels will that  work for them too.
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #9 on: June 12, 2012, 10:39:51 AM »
If there's no lift in the front suspension, you may have bent/bending strut towers. I had to put a brace accross the top of the engine from one strut to the other to hold them in place, and still use the camber bolts.
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
« Reply #10 on: June 13, 2012, 04:08:57 PM »
Back wheels are good, if you lift it more then 2" then you will need a spacer for the third link.
