1989 Intermittant starting problem
  • 2013 Views
Offline mvtracker
« on: June 08, 2012, 04:32:39 PM »
Can anyone give me your ideas on diagnosing a starting issue i have experienced for the last 3 months?
At present, when turning the ignition, the starter is dead. I hear a clicking in the ECM, when turning the key.The clutch safety switch is good. The starter wires are fine and connected. The Geo will run when pushed to start. Initially, the started would hesitate when the ignition key was turned, and then would start. Now its just dead.
Thanks
Re: 1989 Intermittant starting problem
« Reply #1 on: June 10, 2012, 07:25:57 AM »
Try jumping the starter solenoid start lead direct to battery (the battery lead should already be direct to battery).  This will tell you whether problem is at starter.
If that works -check voltage at starter solenoid start lead when ignition switch is turned to start.  Should be almost same as battery voltage.
If it does not work, then jump between the starter solenoid battery lead and starter solenoid lead.  If that works then you need a starter solenoid.
If that did not work, then jump between the battery and starter.  If it does not work have starter tested/replaced.
Some of these trucks have a clicky starter issue.  Presumably the issue is in the starter switch (the major item between the battery and starter solenoid start lead).   There is a clicky starter fix that does not fix anything, but creates a reliable way to start your vehicle if the first test works.
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« Reply #2 on: July 08, 2012, 07:19:34 AM »
try this, I have one and it works well.
http://clicky-starter.com/
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
« Reply #3 on: August 02, 2012, 01:14:00 PM »
Could be ignition switch not getting enough power to the starter
Replace or install a push start - loop wire from battery to button to starter
*Just did it on mine for that reason
1989 2dr Suzuki Sidekick 4wd, 2" Susp Lift, Fender Modification, 31.5/10.5/15 Tires, Hi-Lift
