1999 Suzuki Grand Vitara A/C refrigerant charge - loud squeal
  • 1887 Views
Car = 1999 Suzuki Grand Vitara 2.5 V6, 5 speed / stickshift. US version. Flowmaster Series 40 Delta Flow w/ QTP Cutout.
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
Re: 1999 Suzuki Grand Vitara A/C refrigerant charge - loud squeal
« Reply #1 on: June 09, 2012, 05:58:32 AM »
Remove some of the coolant, sounds overcharged.
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
« Reply #2 on: June 10, 2012, 12:09:05 PM »
Thanks.
Does this car's compressor have a pressure release valve? Is that what the hissing was?
Offline FireCkrEd
  • 246
« Reply #3 on: June 10, 2012, 05:30:00 PM »
I don't know, you may have blown the seals. When you remove some coolant, if it has no pressure then a seal is blown.
          Ed
Offline IanL
  • 466
« Reply #4 on: June 11, 2012, 11:54:55 PM »
I had a similar experience with my V6 - the belt was definitely slipping.  I vented some refrigerant and it works ok now, but the belt must have got polished, because it slips in damp weather.  Going to replace the belts this week.
I think the pressure indicators on these cheap kits are unreliable.
