Need engine for 92 Sidekick
  • 9 Replies
  • 2512 Views
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
« on: June 11, 2012, 06:46:21 PM »
Help, I killed my engine! Popped a hose at 80mph passing a truck and seriously over heated the poor thing. Anyone got a good one for sale. If so, how much, where is it and what is it's condition? ???
The more it snows the happier I get!
Offline Khodabear
  • 155
  • Littleton Colorado
Re: Need engine for 92 Sidekick
« Reply #1 on: June 11, 2012, 06:52:04 PM »
Where are you?
1997 Tracker
1997 X90
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
« Reply #2 on: June 11, 2012, 06:59:42 PM »
Sidney Montana...East side of the state!
Offline Khodabear
  • 155
« Reply #3 on: June 11, 2012, 09:00:32 PM »
Ok - I'm in Denver.
I have a good 8 valve 1.6  block and head - good leak down test results that is.
Came out of a 1991 Tracker.
Motor only - no intake - would need a replacement distributor case part # 11161-60A00 as the one on this motor was broken in the accident that totaled the truck.
Also would need a plastic timing belt cover as the fan cut into the one on the motor.
$195 picked up - $250 put on a pallet and dropped off at a carriers dock in metro Denver.
« Last Edit: June 11, 2012, 09:31:46 PM by Khodabear »
1997 Tracker
1997 X90
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
« Reply #4 on: June 12, 2012, 04:37:15 AM »
If that was a 16v I would be there in this weekend....Thanks though!
Offline Khodabear
  • 155
« Reply #5 on: June 12, 2012, 07:38:06 AM »
Shucks!
(And how often do we get to use the word "Shucks"?)
The only other motor I have is an 8 valve 1.8 from a 97 Sport Kick.
1997 Tracker
1997 X90
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
« Reply #6 on: June 12, 2012, 05:16:38 PM »
Ok, dumbo here, does that 1.8 match up to my trans???? If so, you have my undivided attention again!!!
Offline Khodabear
  • 155
« Reply #7 on: June 12, 2012, 09:02:45 PM »
Equally Dumbo here.
I don't know. It is set up for manual gearbox and supposedly has a rather new clutch.
Hopefully more enlightened minds will stop by and help us both!
1997 Tracker
1997 X90
Offline Khodabear
  • 155
« Reply #8 on: June 13, 2012, 08:43:58 PM »
Talk about Dumbo... I heard timing chain and thought the 1.8 was 8 valve. It's 16.
I asked about the possibility of a swap on the other forum and was advised that it would require everything - I take it that includes the transmission. The one I have is bad.
Sounds like more work than it'd be worth.
1997 Tracker
1997 X90
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
« Reply #9 on: June 14, 2012, 04:45:05 AM »
OFCOURSE it would! It's my luck and it sucks. That would have been great. Upgrading to a bit more engine has been a dream for awhile now.
Ok, Thanks for the efforts and good luck to you!
