87 Samurai stalls after bump
  • 2699 Views
Offline peanuttom
« on: June 17, 2012, 01:25:57 PM »
No success searching for an answer.  I'm new to the forum here.  I have a recurring problem with Samurai stalling and flooding after hitting a hard bump (speed bump or sharp dip in the road).  Immediately stalls and you can smell gas.  Flooding from carb overflow lines.  Restarts after I pull fuel line and crank engine for 1 or 2 minutes.  I have replaced fuel filter and run carb and fuel line cleaner through the gas tank.  I thought maybe the float was sticking.  Saw exact same thread on another forum from 2 years ago, but neither of the 2 having the same problem got a concrete answer.  Any suggestions?  Thanks from a newbie!
Offline SineCredulitas
  • 73
Re: 87 Samurai stalls after bump
« Reply #1 on: June 18, 2012, 11:46:13 AM »
Adjust float?  Rebuild carb while at it?
Good luck.
88.5 TT, dd, 1.6 16v, 5sp, a/c, SPUA, 30" MTR's
« Reply #2 on: June 18, 2012, 03:44:40 PM »
Float sounds likely. Good place to start anyway
