New samurai build
  • 2299 Views
New samurai build
« on: June 18, 2012, 10:50:51 AM »
I just picked up this 87 samurai. Its sitting on toyota running rear and is also gonna have a a 22r put in it. I bought the motor,tranny,transfer case and samurai the way it sits for 1200 dollars.
let me know what you guys think for the 22r swap help would be greatly appreciated.
Like i said its a project in the works
Re: New samurai build
« Reply #1 on: June 18, 2012, 09:20:09 PM »
Looks great. that is an awesome color. I have read about the swap and the person had to modify the front shocks due to the heavier block kept breaking leafs. and I have heard that the 1.6l 16v is pretty much the same and a much easier build.
« Last Edit: June 18, 2012, 09:21:40 PM by leopoldsami »
« Reply #2 on: June 19, 2012, 07:34:28 AM »
Yeah I keep hearing it's a lot easier than the 22r. I got yota leafs so I think it should be good.
Offline zuki1018
  • 397
« Reply #3 on: June 19, 2012, 09:45:40 AM »
Thats a good price.
I have no personal experience with any yota -into-sami experience.  If the drivetrain is all toyota... doing the 22R you would only need to build custom mounts for the install?   ...as opposed to buying an adapter kit from 1.6 to toyota, sourcing a 1.6, and still dealing with custom mounts other than the engine?
I suppose another possible issue going 22R is dealing with a different ignition setup?
Where in FL are you? Tallahassee here.
« Reply #4 on: June 19, 2012, 10:30:21 AM »
Im in st.petersburg. My thoughts exactly the drive shafts would line right up, instead of Being at a crazy angle. I'm going to do a 3 inch body lift so the tranny can clear the tunnel.
