Body lift questions
  • 1836 Views
Offline SDS1992
  • 42
Body lift questions
« on: June 20, 2012, 05:55:02 PM »
Thinking about getting a rocky road outfitters 2 inch body lift. Just wondering if anyone has used this lift and want to know if it's good or bad or if there's another body lift you guys recommend.  Also want to know what's involved in installing it, as I've never done a body lift before. Thanks
2000 chevy tracker 4 door 2.0l 4x4 225xxx miles~ jeffs 2" spacer kit, KYB struts, removed sway bar, XL 7 coil springs in rear with rancho 5158 shocks, 235/75/15 Mastercraft MT tires mounted on 15x8 steel wagon wheels, 1.25" wheel spacers, custom skid plate and 5 inch pipe rocker panels/rock sliders, 2 kc daylighter offroad lights mounted to top of fenders
Offline MUD CHILD
  • 355
  • 9
Re: Body lift questions
« Reply #1 on: June 21, 2012, 12:27:56 PM »
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #2 on: June 21, 2012, 05:31:32 PM »
I have on the RRO 2" body lift. The parts are pretty generic but get the job done. I did body lifts on two GVs using the RRO kit with no problems. Note that you need to lift the front and rear bumpers yourself..
The rear can lift with some 2" spacers, longer bolts and a lil adjustment on the steel bumper.
For the front, I simply cut off the factory mounts and welded them back on 2" lower.
My only complaint is their steering extension. I find the design flimsy and not well engineered. I never liked how the sleeve moves freely over the inner rod and the supplied bolts they sent were too long. Also if you over tighten the bolts, you can crush the rubber damper. (I don't know if I was installing it wrong, I tried on two occasions and always ended up modifying them to be stronger..)
Offline SDS1992
  • 42
« Reply #3 on: June 23, 2012, 01:38:11 PM »
Thanks for the input guys!
Offline zuki709
  • 190
  • 6
« Reply #4 on: June 23, 2012, 03:22:13 PM »
MUD CHILD's lift is awesome top notch quality. i was realy impressed with it when i did my lifts. ;D
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
