alternators
  • 3401 Views
Offline airdale navy
  • 82
alternators
« on: June 21, 2012, 02:58:51 AM »
In the last thread a lot of people when thur a lot of alternators wheeling, are these all stock?Do you have the same problem with a GM alternator conversion?
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Re: alternators
« Reply #1 on: June 22, 2012, 08:01:28 AM »
It would be a SWAG as to what thread you refer to.  Alternators do not last long in muddy water, and bad wiring can cause them to burn up.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: alternators
« Reply #2 on: June 23, 2012, 04:37:27 AM »
I know that the common upgrade is to install a GM / Delco alternator. Are there other alternators that would do the trick without the rewiring / bracket welding to boost up the amps? I read something once about a Mitsubishi upgrade that did just that however I haven't been able to find it again.
Re: alternators
« Reply #3 on: June 23, 2012, 07:17:18 AM »
For the Kickers (55 amp ?) an XL7 alternator (90 amp) is only 3 mm larger diameter and the XL7 is also a little deeper.  The XL7 alternator uses the same 3 wire schematic plus Bat. as the kickers but it uses a different 3 wire plug.  New a 93 Kicker alternator is $105 and an XL7 alternator is $129.  If you use a Tracker/Vitara after '99 alternator, they are larger yet, 70 amps, cost $165, and use the same 3 wire plug + Bat. as the XL7.  (And I was able to use my Tracker alternator as the core for the XL7 alternator.)
Both of these require a different base mounts than the Kickers.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: alternators
« Reply #4 on: June 23, 2012, 06:46:07 PM »
Thanks BRD HNTR... something more to think about...  ;) I just installed a accesory fuse block and think I might even put in a radio now....  :laugh:
I know that once i do it will be too much for my current system. I'm thinking to do an alternator upgrade and put the winch / lights on the accesory block then. Most of the time they won't run and i doubt they will ever run concurrent while I own it. But ya just never know.....  :)
        Tux...  8)
  • 82
Re: alternators
« Reply #5 on: June 24, 2012, 05:15:44 AM »
Thanks for input.
