1.6 16v missing bad!
  • 2662 Views
Offline ldodge92
  • 107
« on: June 21, 2012, 10:43:32 AM »
My 94 4 door 1.6 16v 5sp is missing and running really rough. it smooth out some at about 3300 rpm. I've put. new plugs cap and rotor. have tried adjusting time but doesn't help. any suggestions?
My new addiction
Offline talonxracer
  • 1284
Re: 1.6 16v missing bad!
« Reply #1 on: June 21, 2012, 10:59:54 AM »
Check that the crank bolt isnt loose and the pulley doesnt wobble when running.
Offline kreator
  • 634
  • 15
« Reply #2 on: June 21, 2012, 11:39:44 AM »
Is it missing real bad or is it just shaken , if its missing do a compression check.
Offline ldodge92
  • 107
« Reply #3 on: June 21, 2012, 02:51:59 PM »
Its missing. compression is good.
My new addiction
« Reply #4 on: June 24, 2012, 07:09:20 AM »
Did you put on new plug wires too?  16Vs are real picky about old plug wires.  In my experience, new plug wires usually fix misses in 16Vs.
Offline ldodge92
  • 107
« Reply #5 on: June 24, 2012, 10:38:59 AM »
yeah new plugs and wires to. set the time when about 5 miles then i think it jumped time. looking into it more today
My new addiction
« Reply #6 on: June 24, 2012, 10:56:07 AM »
Very, very rare for it to jump time.  The timing belt would have to be extremely loose, for it to be able to jump time.
What did you set the timing to?  Is the distributor near the center of its adjustment range?
Another thing to check would be the valve lash.
