suzuki samurai egr vacuum modulator?
  • 10223 Views
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« on: April 14, 2004, 08:18:17 AM »
hi all, cant pass smog until i replace the egr vacuum modulator in my suzuki samurai, does anyone know where it is and what it looks like and where i can get a new one? i can probably use one out of my other samurai to  pass but i dont know what it looks like or if it s cheap ill just replace it. any help is much appreciated, 6feet ;D
Offline picklepants
  • 42
Re: suzuki samurai egr vacuum modulator?
« Reply #1 on: July 31, 2008, 12:47:50 PM »
i dont know where to plug in my EGR modulator cus i had a webber carb on my ever since i owned it and im having trouble finding where to plug it in to the stock carb. PLEASE HELP
Offline HOGCAT
  • 20
« Reply #2 on: July 31, 2008, 03:49:01 PM »
  Here ya go.  Pretty simple if you just look at one system at a time.  Any questions just ask.
http://www.acksfaq.com/Samvacuumlines.php
  There are two vacuum lines on the modulator valve.  They are labeled "P" and "Q"  Make sure they go to the right valves.  The "Q" goes to the 3 way solenoid valve (TWSV).  The "P" goes to the Bimetal vacuum switching valve (BMSV)  and then to the ported vacuum pot on the carb.  The big line goes to the big nipple on the EGR valve.  The back pressure from the exhaust when your engine is pulling power is  pushed  into the EGR modulator and lets the vacuum open the EGR.  This way the EGR is not working when at idle.
  You need to download the service manual to get a clear pic of how the hoses are routed.  Here is a link to download  the service manual.  Its in 3 seperate sections, but look for the part you need now.  But save all 3 sections for future use.
http://wewt.net/cars/88samurai/fsm/
« Last Edit: July 31, 2008, 04:08:31 PM by HOGCAT »
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #3 on: November 20, 2009, 03:17:15 AM »
The labels are on the cover of it.  I removed the modulator from the vehicle and then removed the cover to check the small filter in it.  How do I tell which is P and Q now?   I don't know if I put the cover back on the same way.
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
« Reply #4 on: November 28, 2009, 12:03:41 PM »
The P and Q shouldn't be on the top cover cap, they should be on the side of the modulator body, right above where the vacuum line's plug in.
« Reply #5 on: December 01, 2009, 01:16:50 PM »
The P and Q are in fact on the top cap.  There are no markings on the body itself that indicate which port is which.....at least on any zuk modulators I have seen.
If you have another modulator around, pop the cap off (mark it first), pull the filter out and look to see which is which.  IIRC, I don't think it matters....but it's been awhile since I had one apart.
