Larger tire on a Tin Top
  • 2030 Views
Offline Effzuki
  • 41
  • When in doubt, punch it out!
« on: April 13, 2004, 06:13:49 AM »
Has anyone cut/knocked/kicked/hammered  :o the wheel wells on a Samurai to fit  P235/75R15 (28.95â€? overall diameter) or an LT30X9.59R15 (29.3â€? diameter) tires?  Will they fit? Should I, or will I have to buy the wheel spacers?  I’m looking to “liftâ€? the axles up a little.  Will my 88.5 Samurai with a 1.6, 8V turn those tires if they will fit?  Thanks.
88.5 Tin Top and never will be done with it.
Re: Larger tire on a Tin Top
« Reply #1 on: April 13, 2004, 06:37:40 AM »
My daily driver soft top had 30's on it with just a little trimming of the bumper brackets. Having said that remember that all tires are slightly different.
Offline Effzuki
  • 41
« Reply #2 on: April 13, 2004, 07:56:48 AM »
I’m keeping this a daily driver also with off road capabilities.  I got those dimensions from Cooper Discoverer SST’s.  I’m guessing most tires will be in the ballpark.  Is the spacing/off set of the rim a factor during a tight turn?
« Reply #3 on: April 13, 2004, 12:57:54 PM »
It would rub a tiny bit at full sterring lock and full compression.
Offline Effzuki
  • 41
« Reply #4 on: April 14, 2004, 05:21:54 AM »
Would larger shackles keep it from rubbing?  I was thinking 1-3/4" larger than stock.
