what is the biggest tire i can fit
  • 2543 Views
Offline Jakezuki
  • 21
« on: June 25, 2012, 08:18:05 PM »
i have a 92 sammi i would like to put a bigger tire on but dont have the $ for a lift at the moment i have a set of 30/10.5 wondering if they would fit without any mods and what is the best way to get a little more height without spending a bunch of $
Offline SIDEKICK65
  • 176
Re: what is the biggest tire i can fit
« Reply #1 on: June 25, 2012, 11:32:01 PM »
Y not just put your. axle's under your leaf spring's? It's cheap and easy.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #2 on: June 26, 2012, 08:37:33 AM »
Cheapest easiest way would be lift shackles to edge a 30" tire on.
« Reply #3 on: June 26, 2012, 12:23:43 PM »
For stock tire swaps 235/75 R15 is the generally accepted largest you can go before a lift is needed.
Offline tombstone
  • 212
« Reply #4 on: July 31, 2012, 08:01:35 PM »
  Maybe not so "easy" for someone who has never done a SPOA.You have to know that you "swap" front bottom u-bolt brackets AND that you grind off the "tin" plate on the front axle and smooth it out to accept new leaf pads...little stuff like that!!Oh and you have to "drop" the drag link 3-4 inches too.
