Winch
  • 3016 Views
Winch
« on: June 29, 2012, 01:04:22 PM »
I just picked up a brand new Smittybilt x20 8.  It's a step up from the XRC 8.  The only difference I can tell is that it is completely water proof.  It is brand new and hasn't been used, and I only paid $300.  It runs about $500 new I believe.  The only problem I have, is that it is pretty heavy, and seems big.  I don't want it took look to over kill on my Zuk.  your thoughts?  Here are some pics of my Sammi.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Winch
« Reply #1 on: June 29, 2012, 01:32:37 PM »
8K is pretty much the standard rating for a Samurai.
You don't want the danged thing to break when you REALLY need it...
Ack
Re: Winch
« Reply #2 on: June 29, 2012, 01:43:07 PM »
Yea, that's what I have been told.  What are your thoughts about a removable hitch style mount vs fixed?  That way I can hook up in front and back.
Offline ack
  • 1659
    • Ack's FAQ
Re: Winch
« Reply #3 on: June 30, 2012, 08:58:55 AM »
That seems to be a convenient setup!
However, picking up an 8k Winch mght be similar to cleaning up after Futurama's Nibbler when he makes poo...
That part would get old quickly - especially if you are over 26.
Ack
Re: Winch
« Reply #4 on: July 02, 2012, 09:35:24 AM »
Warn makes a part called the Multi-Mount, which allows you to do that. It's a pretty convenient little setup.
- Andy
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Offline jrok90
  • 17
Re: Winch
« Reply #5 on: July 13, 2012, 08:14:22 PM »
years ago I had and 84 toyota and winched out backward by running the cable under the axles and out the back....it worked.
Offline kbeefy
  • 17
Re: Winch
« Reply #6 on: July 21, 2012, 03:03:37 PM »
I run an 8k on mine, wouldn't run anything smaller.
Multimounts are fine for an occasional winch or multiple vehicles, but they stick out too far and are weak in a side load imho. I've seen mounts with 2 recievers on them, those would be better.
Running your winch underneath would work in a pinch, but if your stuck in mud it wouldn't be very fun getting it through there. Also terrible on your cable making that sharp of a bend at the fairlead.
Offline tombstone
  • 212
Re: Winch
« Reply #7 on: July 31, 2012, 07:51:04 PM »
I am going with a 5K winch from Harbor Frieght,its only $199!!The 5K winch only wieghs 35lbs too! ;)
Offline smife
  • 179
Re: Winch
« Reply #8 on: August 01, 2012, 05:15:34 PM »
I have (2)  xrc8's. One on the trailer (for picking up blown up Trackers)  and one on my Tracker. The one on my Tracker has rope line instead of wire line. I can carry the winch in one hand. All 8k winches are heavy. I wouldn't go any smaller unless you are only going to use the winch on asphalt. The waterproof winches may be heavier, I haven't checked....
Mount it tight to the body and you'll be fine..............
