Technical Discussion - Beginner / Repair
t case problems
t case problems
scuba*88
4
t case problems
July 02, 2012, 05:44:40 PM »
T case makes popping noise under a load and tries to pop out of gear... Any ideas
ecoast
509
8
You tube my space, and I'll google your yahoo
Re: t case problems
July 03, 2012, 05:00:43 AM »
front output shaft is broken?
...you can pull front d-shaft & t-case cover to check with case in rig...
mrfuelish
2862
13
you must have a perception problem.
Re: t case problems
July 03, 2012, 06:46:42 AM »
Don't put it under a
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
scuba*88
4
Re: t case problems
Reply #3 on:
July 03, 2012, 09:57:23 AM »
That was the description I was given on a case I was thinkin about buying. And somebody took the shifter out of it
ecoast
509
8
Re: t case problems
Reply #4 on:
July 04, 2012, 12:44:33 PM »
...then it's a pig in a poke.
plan on rebuild, or at least cracking it open.
