4 speed auto question....
  • 14 Replies
  • 4879 Views
Offline airdreams1
  • 90
« on: July 05, 2012, 03:35:15 PM »
Im doing the 1.6 16v motor swap  & was wondering if anyone has done the matching 4 speed auto |removethispart|@ the same time?  (Trail tough sais I can have my harnice setup to use the trans at the3 same time & have it modifyed.)
Also wandering if there are any reliability issues with this trans if I do it.
& No I dont realy want to mess with the Volvo  4 speed thing.  it will cost way more in the long run.
any help would be appriciated.
87 Samurai  soft top
Re: 4 speed auto question....
« Reply #1 on: July 05, 2012, 06:07:22 PM »
The Volvo 4-speed is the same transmission, just without the wiring.  So any documentation covering it will work with your conversion.
Have you looked into a Kicker 3 setup?  That would give you the dual t-cases as well.
Offline airdreams1
  • 90
« Reply #2 on: July 07, 2012, 12:00:49 PM »
from what Ive read the Volvo/toyota 2wd trans can bolt up to the kick bell housing. but Ive heard that its much longer so you have to relocate the transfer case & make your own interediat shaft, etc,etc.....
I dont realy have a use for doual transfer case setup... the rig is going to be a daily driver  with ocasional off road use. (ie: camping, shooting & what not.... thatsaid Im looking for the 4 speed w/ lockout for freeway mpg....  I need the best mpg I can get.   + we have 75 mph speed limit here so I dont want it geared so low thatI top out |removethispart|@ 50....
Its hard to beleve that no one has had Trail tough do this yet???????  They said the can  do it & have. I just want to hear frm someone that has done it  to get some actual feedback.
87 Samurai  soft top
Offline 96sport
  • 39
« Reply #3 on: July 10, 2012, 07:27:09 AM »
a company called RADesign (i think) has a shifter that eliminates the need for a TCM. it makes the trany manually shifted but its an option, then you can use the suzuki trans. thinking of using it in my kick.
Offline klslaker
« Reply #4 on: August 07, 2012, 01:07:48 PM »
Does anyone have more info on the product mentioned for shifting for the 4spd OD without the TCM? Looked for Radesign but no luck. I have a couple of these Suzuki (Aisan) 4spds and would luv to know more.
Offline fordem
« Reply #5 on: August 07, 2012, 02:54:58 PM »
Ever heard of Google ?  first hit - http://www.radesignsproducts.com/
« Reply #6 on: August 08, 2012, 03:46:20 PM »
This would be GREAT for me, I'd love to have the 4th gear of the newer trans in my 95, but I looked and didn't see anything about the GM/Suzuki trans. I also don't want to go through all the swapping and switching to get a Volvo trans in mine. I'd be more than happy manually shifting an auto as long as it's a Zuk bolt in.
Offline 96sport
  • 39
« Reply #7 on: August 09, 2012, 06:38:35 AM »
i emailed the guy and he said it would work on my 96 sport.
Offline fordem
« Reply #8 on: August 09, 2012, 10:17:18 AM »
As I understand it the 4 speed auto in a Vitara/Grand Vitara is an Aisin Warner AW4 - which is listed - but I've never had the opportunity to confirm that.
« Reply #9 on: August 09, 2012, 03:14:12 PM »
Now , all we need to figure out is if the 4 speed will physically fit the 1.6 without a whole bunch of mods. Didn't the later 2nd gen Trackicks get a 4speed with the 16V 1.6?
Offline fordem
« Reply #10 on: August 09, 2012, 08:31:12 PM »
As I understand it, even first generation Trackicks had the 4 speed auto - don't ask  me which ones - but some of them did, and yes, all of second gen automatics were 4 speeds.
Offline Skyhiranger
  • 3734
  • 122
« Reply #11 on: August 09, 2012, 08:52:43 PM »
First gen. 4 door trackicks got the 4 speed auto (except for the oddball 91 4 door...which got the 3 speed).  All first gen. 2 doors got the 3 speed auto.
« Reply #12 on: August 10, 2012, 04:54:34 AM »
Thanks Sky. So, aside from the difference in rear driveshaft length of the 4 door, I'm thinking the bolt patterns for the bell housings are the same as the 3 speed, therfor it should bolt right up to the 1.6 16V block. If that's the case, I'm gonna start looking for a good 4 speed, and get the info on that manual shifting box. Anyone got a good 4 speed  ;D
Offline Skyhiranger
  • 3734
  • 122
« Reply #13 on: August 10, 2012, 05:22:51 AM »
Yeah the BH BP is the same between the 3 speeds and 4 speeds, since the 8V and 16V both use the same blocks.  The front dshaft is also a different length, because the 4 speed is a little longer than the 3 speed and 5 speed.
The 4 speed also used a different flex plate and TC, so you want to be sure and get those too.
« Reply #14 on: August 10, 2012, 03:47:24 PM »
Got it, thanks Sky. So I'm gonna need the trans, flexplate and TC, maybe the driveshafts too. Now to statr lookin for a good one.  ;D
