22r conversion
  • 2203 Views
22r conversion
« on: July 17, 2012, 09:45:34 AM »
I need some help.  I purchased this Sammi a few months ago, and the conversion wasn't done quite as well as I wanted.  The 22r was put in buy a toyota ASE certified mechanic.  The axels and undercarriage were done by 4x4 outfitters out of Durango.  The problem I have is with the 22r swap.  The wiring that was done is horrible.  I had to replace the alternator almost immediately.  Now I am not receiving a charge, and the wiring from the alternator to the fuse box is a mess.  All the wiring was pretty bad to be honest.  My question is, is there a wiring harness already set up for a 22r conversion to the Samurai?  I could build one, but it would be much easier, if this has already been done.  Thanks!
Offline super pc
  • 49
Re: 22r conversion
« Reply #1 on: July 19, 2012, 10:47:14 AM »
Okay, I have swapped several alternators around on my old yota's.  What I have encountered is a no charge situation.  What I found out was that on the toyota truck it ran through a charge relay and throught the gauge, I just happened to have a gauge that was not functional, therefore, no charge.  Long story short, get yourself a gm one wire and bolt her on.  If I remember correctly I didnt have to build a brack, the yota ones worked fine with slight modification.
87 Sami- SPOA, 2" springs, HID 7"x2, 32X11.50 TSL's, aftermarket buckets, 3 piece top, hi-lift, Thorley header, magnaflow full system, weber carb, OTT
08 Tundra Leveling kit, 34's, charcoal stockers, tinted tails, 5% tint all around, JVC deck, Pioneer 12", 300w Rockford amp
Offline oneal
  • 38
Re: 22r conversion
« Reply #2 on: July 21, 2012, 12:36:43 PM »
 Pretty damn hard to screw up a 22r swap lol! all I did was modify the stock 22r bracket(minor grinding)and bolted in the samurai alt then used the same starter wires....done.Why would someone go through all the trouble of modding the harness??
