transfer case oil
  • 10 Replies
  • 8562 Views
transfer case oil
« on: July 17, 2012, 07:02:59 PM »
what is the best grade gear  oil  to use in a 4.16 transfer case?
Offline Jonny Rash
  • 1094
  • 21
Re: transfer case oil
« Reply #1 on: July 18, 2012, 07:04:51 AM »
Just the standard gear oil, 80w-90.
Offline kreator
  • 634
  • 15
« Reply #2 on: July 18, 2012, 08:28:33 AM »
80 / 90 with a gl4 / gl5 rating
Offline mike5721947
  • 545
« Reply #3 on: July 18, 2012, 09:20:09 AM »
75-90 synthetic. i know my kick cant run 80-90 once it starts getting cold. had it happen in alberta where it was so thick in neutral it would stall the engine. but thats -20 -30 out...
31" kumhos 3inchs of lift.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #4 on: July 18, 2012, 11:05:11 AM »
they say gl-5 ok  IF 'white metal safe'
« Reply #5 on: July 18, 2012, 11:54:36 AM »
Shouldn't that be "yellow" metal safe?
Some GL-5 oils use sulphur as an EP (extreme pressure) additive, and the sulphur can attack brass & bronze, which are yellow in color, hence the term.
Offline Jonny Rash
  • 1094
  • 21
« Reply #6 on: July 18, 2012, 01:31:44 PM »
You guys sure seem to be splitting hairs.   ;)
Just grab the gear oil from Wally World or your local autoparts store.  It will work fine and has been run in a 4:1 t-case of mine for 10+ years. :P
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #7 on: July 18, 2012, 01:36:16 PM »
yes, brain fart--lol
« Reply #8 on: July 18, 2012, 05:54:40 PM »
If the t/case is from a first gen trackick you can run what you want, if it's second gen it does make a difference - now - do you want to be the one wlaking into Autozone and asking for a "white metal safe" GL5?
Offline Jonny Rash
  • 1094
  • 21
« Reply #9 on: July 18, 2012, 08:36:24 PM »
4.16--> Samurai t-case
« Reply #10 on: July 18, 2012, 08:43:22 PM »
If I'm right the Samurai t/case has no synchros, so you'd be safe with a GL5 there too.
