Stubborn axels…
  • 12 Replies
  • 3931 Views
Offline Kreg
  • 795
    • Island 4x4
Stubborn axels…
« on: April 08, 2004, 06:42:05 PM »
Started to install my locker today, but unfortunately I never got very far before I had to head out for dinner.
When I was trying to pull the axels out, so I could take out the 3rd member, they wouldn't budge.
I took off the 4 bolts on the back of the drum that hold the retaining plate. That should be the only thing besides the C-clip that is holding the axels snug right?
Am I missing anything?
I wish I could find my Haynes manual.  :'(
Offline hargraves
  • 33
Re: Stubborn axels…
« Reply #1 on: April 08, 2004, 08:35:09 PM »
c clip what are you working on a chevy?
no the wheel bering is pressed into the axle tube.
all you have to do is put a chain around it and yank on it,
or use a slid hammer if you have one.
oh and if it is a samurai you need to take the brake lines loose from the wheel cylinders.
Offline 1bigtracker
  • 3409
Re: Stubborn axels…
« Reply #2 on: April 08, 2004, 11:00:36 PM »
ya you have to use a slide hammer or some red neck version out it.  their are no C clips.
stu
Offline Speedracer7c
  • 2210
Re: Stubborn axels…
« Reply #3 on: April 08, 2004, 11:06:13 PM »
mount the brake drum on backwards and smack it with a big rubber mallet. Or a 5lb sledge and a block of wood.
Offline 1bigtracker
  • 3409
Re: Stubborn axels…
« Reply #4 on: April 09, 2004, 12:08:03 AM »
oh thats a good one. i never thought of that.
stu
Offline Kreg
  • 795
    • Island 4x4
Re: Stubborn axels…
« Reply #5 on: April 09, 2004, 03:33:25 AM »
What I did was bolted a chain to two of the studs and made a big loop.  Then I put the head of a sludge hammer through the loop and had at it.  I'll try it again today.  I was just making sure nothing else had to be loosened off in order for it to come out.
Yes, actually I am :P
My truck is a chevy Tracker.  :D
« Last Edit: April 09, 2004, 03:34:05 AM by Kreg »
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Stubborn axels…
« Reply #6 on: April 09, 2004, 02:53:50 PM »
Places like Auto Zone rent things like slide hammers for free!
That's what I use and never had a problem.  Though I do have my own.
32 MTR's Warn 8000i
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Stubborn axels…
« Reply #7 on: April 09, 2004, 02:57:19 PM »
RENT THINGS FOR FREE  :-/ IT MUST BE THEY LOAN THEM AYE  ;D  ::)    ;)  ......YEA MY WIFE ALL WAYS TELLS ME I'M A SMART A$$   :P  MATTY D. 8)
Offline idaholwb
  • 772
Re: Stubborn axels…
« Reply #8 on: April 09, 2004, 07:39:15 PM »
 CHEVY(?) Tracker? Don't you mean the rebadged SIDEKICK?
HEHE!!!
I made a slide hammer out of an old twisted axle and some square tubing and angle iron. Sometimes the bearings get a cold fusion thing going on and they are a bear to get out, even with a slide hammer.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Kreg
  • 795
    • Island 4x4
Re: Stubborn axels…
« Reply #9 on: April 10, 2004, 04:23:00 AM »
. Hehe ya I was just being a smart |removethispart|@$$.  :P
I borrowed a friends slide hammer and finally got the damn things out.
I got the locker installed last night. When I set all the gears back up the backlash was perfect and things went pretty smoothly.
The Lock-rite instructions are very good and make the process very simple and clear.  The only bummer is that when I went to put the drums back on last night the brake pads spread and I couldn’t fit the drum back on.
I had to remove the big spring on the backing plate so I could get the retaining plate to pass through.  When I put the springs back on I think something unloaded in the process and the brakes don't work the way they are suppose to.
I'm just about to head out to the shop so I can get them working again, then I'm going to slap on the tires and see if the locker functions properly
  • 2274
Re: Stubborn axels…
« Reply #10 on: April 10, 2004, 04:49:37 AM »
SOUNDS GREAT ! SHOULD MAKE A BIG DIFFERENCE IN YOUR TRAIL RIDING  ;D  MATTY D.  8)
Offline Kreg
  • 795
    • Island 4x4
Re: Stubborn axels…
« Reply #11 on: April 10, 2004, 07:13:31 PM »
Got the brakes working this morning.
I guess there’s an adjuster lever that opened up when I took the spring off.  I just pushed the lever closed and the brake pads went back to their normal position.
The locker works great.  Took a bit to get use to at first, but I think I got it figured.
Turning corners is a whole new ball game now.  If you don't have the right amount of throttle applied the rear end starts bucking.
The ratcheting sidegears are kind of noisy, but I don't mind them.  Haha I thought my truck got a lot of looks when I just had the lift in.  Now when the ratchets are clicking away, EVERYONE turns their head’s.  :P
Offline 1bigtracker
  • 3409
Re: Stubborn axels…
« Reply #12 on: April 11, 2004, 02:06:02 AM »
ya thats what happens when i go around a corner with the welded rear.  you here one rear tire cherping.  never a hop though?
stu
  ÂÂÂÂÂÂÂ
