Removing the rocker trim support.
  • 4475 Views
« on: July 23, 2012, 05:45:56 PM »
Does anyone know the best way to remove the metal support for the plastic molding on the rocker panel below the doors? I've taken the plastic molding off already but the metal support seems to be on there pretty good either glued or welded, I can't tell. Though I don't see any welds. Let me know if anyone has removed it successfully.
Thanks
Offline Merlin93
Re: Removing the rocker trim support.
« Reply #1 on: July 23, 2012, 08:48:12 PM »
Your answer might be contained here:
http://zukiworld.com/month_110105/feature_calmini_rocksliders.htm
Offline WAGON08
  • 78
« Reply #2 on: July 25, 2012, 12:06:22 PM »
  When i did mine i removed the plastic panels then i just took a flat head screwdriver and started slowly just working it behind the support.  Its tacked  every 6'' to 8''  when i would find a spot that was tack i would just break the weld with the screw driver and a hammer. A little tuff on the metal work but i was planning on redoing that anyway.
87 sami
30x10.5 maxis mudders
stock 1.3L
Offline Godzuki84
« Reply #3 on: July 25, 2012, 02:33:13 PM »
I removed mine the same way.
The little zuki that could
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #4 on: July 28, 2012, 02:53:09 AM »
If you have access to a die grinder with a cutting wheel or a spot weld remover drill bit these both do a nice clean job with a minimal amount of body work to remain.
« Reply #5 on: August 08, 2012, 03:51:29 PM »
Thanks
what did you do w/ the plastic pieces?
Offline my996duc1
  • 222
« Reply #6 on: August 11, 2012, 12:13:33 AM »
The spot welds are there and you have too look really close to see them.
I used a spot weld cutter. Just chuck it up in your drill and you are set. Super simple to use.
Cheap = $5
Worked great and is made exactly for this type of stuff.
http://www.harborfreight.com/3-8-eighth-inch-double-sided-rotary-spot-weld-cutter-95343.html
_
« Last Edit: August 11, 2012, 12:15:14 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
